Do You Have any of these?
Forum topic by Dale J Struhar Sr posted 06-06-2011 07:25 PM 1594 views 0 times favorited 8 replies Add to Favorites Watch
View Dale J Struhar Sr's profile
Dale J Struhar Sr
493 posts in 3093 days
06-06-2011 07:25 PM
I recieved this in an email today and I thought I would share._
How many of these do YOU have???
1.DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it.
2.WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light . Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, ‘Oh shit!’
3.SKILL SAW: A portable cutting tool used to make studs too short.
4.PLIERS: Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
5.BELT SANDER: An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
6.HACKSAW: One of a family of cutting tools built on the Ouija board principle: it transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
7.VISE-GRIPS:Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
8.OXY-ACETYLENE TORCH: Used almost entirely for setting various flammable objects in your shop on fire.
9.TABLE SAW: A large stationary power tool commonly used to launch wood projectiles to test wall integrity.
10.HYDRAULIC FLOOR JACK:Used for lowering an automobile to the ground after you have installed new brake shoes, trapping the jack handle firmly under the bumper.
11.BAND SAW:A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
12.TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of everything you forgot to disconnect.
13.PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
14.STRAIGHT SCREWDRIVER : A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws and butchering your palms.
15.PRY BAR:A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
16.HOSE CUTTER: A tool used to make hoses too short.
17.HAMMER : A kind of divining rod to locate the most expensive parts adjacent the object you are trying to hit.
18.UTILITY KNIFE:Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use.
19.”SON- OF-A-BITCH” TOOL: Any handy tool that you grab and throw across the garage while yelling the afore-mentioned phrase at the top of your lungs. It is also, most often, the next tool that you will need.
-- Dale, Ohio
8 replies so far
View Occie gilliam's profile
Occie gilliam
505 posts in 3259 days
#1 posted 06-06-2011 10:58 PM
Thanks Dale for the comic relief
-- OC down in Costa Rica. come down and see me some time. I'll keep the light on for you too-oc@hotmail.com mail.com
View dlmckirdy's profile
dlmckirdy
199 posts in 3096 days
#2 posted 06-06-2011 11:09 PM
Have you been hangin’ out in my shop?
-- Doug, Bakersfield, CA - I measured twice, cut it twice, and it is still too short!
View Roger's profile
Roger
20923 posts in 2766 days
#3 posted 06-07-2011 01:36 PM
I have thousands of no. 19
View brianinpa's profile
brianinpa
1812 posts in 3685 days
#4 posted 06-08-2011 03:15 AM
I am lacking only three. Some (#19) I have a surplus supply.
View BentheViking's profile
BentheViking
1782 posts in 2526 days
#5 posted 06-08-2011 03:35 AM
Nice
-- It's made of wood. Real sturdy.--Chubbs Peterson
View stefang's profile
stefang
15881 posts in 3297 days
#6 posted 06-08-2011 04:02 PM
All of the points might be summed up as ‘the learning curve’. Thanks for the laugh Dale.
View Richard's profile
Richard
1916 posts in 2653 days
#7 posted 06-08-2011 09:42 PM
I have had most of them at one time or another. More #19 than others.
View Time2beupinAZ's profile
Time2beupinAZ
453 posts in 2924 days
#8 posted 06-08-2011 10:32 PM
I think i am missing a few tools but found out I definetly need them, Now that I know what they do. Thank you.
-- Tim - I usally measure twice after I cut......then I know for sure that I cut it short.....
