Choosing HVLP Needle Size
Forum topic by Ripthorn posted 712 days ago 2635 views 1 time favorited 6 replies Add to Favorites Watch
View Ripthorn's profile
Ripthorn
487 posts in 1150 days
712 days ago
Topic tags/keywords: hvlp spray spraying finishing
I got a turbine-driven HVLP spray gun a while ago and have started my first real finish job with it. I am currently using Emtech EM6000 from target coatings (waterbase lacquer), but I was wondering, what relationship should there be between finish viscosity and tip size. This lacquer is relatively thin compared to other finishes. I thought that you used a smaller tip for thicker finishes to produce a finer atomization, so I have tried the two larger tips so far (only that many coats) and found that each have laid down too much material (orange peel city) even with the spray control set very low. Am I totally missing the mark here? Should I be using my smallest tip? I was making relatively quick passes, so I don’t think that’s an issue. Any experts out there care to chime in?
View PurpLev's profile
PurpLev
7729 posts in 1813 days
#1 posted 712 days ago
thinner material = smaller needle size.
thicker material = larger needle size (otherwise the material will be too thick to pass through)
View DLCW's profile
DLCW
505 posts in 819 days
#2 posted 709 days ago
I tried that same finish a few years ago and found it to be REALLY sensitive to temperature and humidity. It didn’t matter what tip I used in my turbine sprayer. I either ended up with orange peel or fish eye. I went through the whole process of cleaning and prepping and couldn’t get the finish to cooperate. Talked for a while with a tech rep and still had problems. I finally sanded it all off, got some precat lacquer, shot it on and got a perfect finish first time. Now I use ML Campbell conversion varnish and get really good, durable finishes every time.
-- Don, Diamond Lake Custom Woodworks - http://www.dlwoodworks.com - "If you make something idiot proof, all they do is make a better idiot"
View Earlextech's profile
Earlextech
591 posts in 855 days
#3 posted 708 days ago
Tip size with HVLP does not relate to material thickness. It relates more to the type of finish you want. If I am painting I use a 2mm. If I am finishing I use a 1.5mm (even if I’m finishing with paint!). Very simple.
All materials sprayed through HVLP should have the consistancy of cream (for your coffee). Remember it’s low pressure, you can’t push really thick materials through HVLP even with the biggest needle.
Don’t confuse the old fashioned high pressure systems with HVLP. With high pressure everything will go through, then you change the needle to accomadate the thicker material.
-- Sam Hamory - The project is never finished until its "finished"!
View MarcusM's profile
MarcusM
31 posts in 1145 days
#4 posted 708 days ago
Sam. that’s interesting; would you say that also applies to compressor driven HVLP guns?
Thanks, Mark.
-- Tilbilly Mark
Earlextech
#5 posted 708 days ago
I personally don’t like conversion systems but, yes, if you are spraying at 10 psi or lower it isn’t really about adjusting the needle size, it’s about thinning to the proper consistancy.
A typical two stage turbine produces about 2 psi. Granted, a bigger opening (say 3mm) will allow thicker fluid to pass through, but it won’t atomize it properly. The consistancy of any material flowing through an HVLP gun needs to be that of ‘heavy cream’ and it will atomize. Then you can use the needle size to create the best atomization size for the job at hand.
Remember the important number with HVLP is cfm.
View KnotWright's profile
KnotWright
245 posts in 1653 days
#6 posted 708 days ago
If you finish is “orange peeling” it could be that its not getting enough time to flatten out before it drys. In either low humidity, or high temperatures water based finished will dry out faster and cause orange peeling. I have never tried this product in a latex varnish but might be worth a shot. It does a great job with latex paint in helping them lay flat and gives you a little more open time.
http://www.flood.com/paint-additive-solutions/products/view-product.jsp?productId=12
I have not tried water based lacquer, although I do spray a large amount of waterbourne polyurethane varnish using a compressor driven HVLP sprayer. It tends to lay flat without any orange peeling problems.
-- James
