New/Upgrade my Tablesaw Fence - Noobie needs help
Forum topic by Nodak7mm posted 719 days ago 1092 views 1 time favorited 14 replies Add to Favorites Watch
View Nodak7mm's profile
Nodak7mm
21 posts in 725 days
719 days ago
Topic tags/keywords: question
Hi Guys,
I have a decent working tablesaw, a delta 10” #34-740. I would like to replace the fence, the current installed standard fence leaves alot to be desired.
I am Noob to wood working tools, dont know whats good, great, & top shelf. I would like a decent fence, not a cadillac..
The Delta T2 System? Is this decent, worth the 150? Shop Fox? etc..
Suggestions & comments welcomed.
Thanks,
Rod in Fargo.
-- You need to try everything to honestly evaluate anything.... Anonymous
14 replies so far
Nodak7mm
#1 posted 719 days ago
Morning Folks,
Appears I may have answered my own question after about 3 hrs of researching older posts and reveiws. Maybe I was just excited to get my first post outta the way, dunno. But I know now a bit more about fences and feel I can make an informed decision as there are really only 3-4 common names out there to consider. That and Tools-Plus has a heck of a Fathers Day special going on.
Thanks for your paitence.
Rod in Fargo
12073 posts in 1513 days
#2 posted 719 days ago
check the delta t-2
some drilling but like a bessemyer
http://www.google.com/products/catalog?q=delta+t-2+fence&oe=UTF-8&um=1&ie=UTF-8&tbm=shop&cid=5020088936247638784&sa=X&ei=_M7sTZugKqjc0QGxpLjAAQ&ved=0CE0Q8wIwAw
View mrg's profile
mrg
483 posts in 1172 days
#3 posted 718 days ago
T2 will bolt directly to your saw. You will like it.
-- mrg
View knotscott's profile (online now)
knotscott
4215 posts in 1548 days
#4 posted 718 days ago
Is the 34-740 a full size contractor saw (27” deep)? If not, the fences may need to be cut down. The T2 is a great bang for the buck…tough to beat for value and performance if it’ll fit.
View WinterSun's profile
WinterSun
158 posts in 782 days
#5 posted 717 days ago
I’ve got a T2 on my saw and I wholeheartedly recommend it.
-- Rory // Winter Sun Woodworking // Milwaukee, WI
View 000's profile
000
3352 posts in 789 days
#6 posted 717 days ago
Folks’ll drool over the Delta T2
-- When the moderator chooses sides, his site sucks.
View mfike's profile
mfike
100 posts in 1838 days
#7 posted 717 days ago
I think the incra qualifies as a cadillac.
View DYankee's profile
DYankee
2785 posts in 734 days
#8 posted 717 days ago
I like the Incra but agree its probably a bit much for a newbe. The Delta T2 is more reasonable for a newbee with good results.
-- Shameless - Winner of two Stumpy Nubs Awards
View reggiek's profile
reggiek
2238 posts in 1442 days
#9 posted 717 days ago
I agree with August….and with Mfike….I would call the incra a cadillac…but there are father’s day sales by incra going on also…and you can get a decent deal on the Incra fence now.
The incra fence is excellent…with micro adjustment…and reference scales so that you can make easily repeatable cuts…(I make my own story stick and insert it into the incra positioner (it has slots for putting in templates – or you can use the ones they supply).....The incra is really one of the best fence systems going….and easy to install….mine took me about 20 minutes and just a few more to adjust and test. I also have the biesemeyer knock off for my grizzly…it fell short of what I can do with the incra.
Nodak7mm
#10 posted 717 days ago
Guys,
Thank you for the supportive & positive comments.. One of the downside of my location is no place to go look/see/touch & feel these products. Much less find a knowledgeable user.. One of the few times I miss living in a metro area…
Rod in Fargo
View Dan's profile
Dan
3480 posts in 1053 days
#11 posted 717 days ago
I went with the Delta T2 fence for my Delta Contractors saw. Its a good fence and so far mine has remained square. The only negative I would have with the T2 is the ability to make fine or micro adjustments easily. With my original delta fence that came on the saw I was able to move the fence by turning the locking knob. That came very handy when I just needed to make a fine adjustment. I wish the Delta T2 would have had something like that. Still a great fence though.
-- Dan - "Collector of Hand Planes"
View Samwise's profile
Samwise
45 posts in 789 days
#12 posted 716 days ago
I recently posed this same question, and I ended up going with the Shop Fox Classic. I got the fence with 7’ rails for $300. Thought about the Incra, but couldn’t justify the cost. I tried….but knew the wife wouldn’t agree with any of my reasons.
-- Sam
Nodak7mm
#13 posted 716 days ago
Welll,
With luck the wood gods may be shining tomorrow. I have been chatting with a coworker who is a tool junkie and he mentioned he has a fence he doesent use. Found out today it is a new in the box Incra. He has a vega he prefers. I told him to figure out what he wants for it and get back to me tomorrow.
So, I have gotten some screaming deals from him in the past and I am hoping his pattern of “being a nice guy” holds thru.
So who knows, maybe I’ll get the deal of the century on an Incra for the cost of a T2. Stay tuned for tomorrows report.
Rod in Fargo
Nodak7mm
#14 posted 715 days ago
Ok,
Day 5 of Fence decision delimma. Regarding the Incra TS-III system I can get for, yes a screaming deal, will not work for me. Being a Noob, I did not grasp the importance/difference between a 22” & a 27” saw. This Incra fits a 27” saw and I have a 22” saw. This is ok, because I made the decision pass on the Incra anyhow due to necessary real estate needed to utilize it (6’ dual rails).
So, in short will there be in issue with using the Delta T2 on a 22” table? Should a guy modify it or leave it as is and deal with it?
Thanks guys, I already have learned more about table saws in the past 5 days than all previous 47 yrs..
Rod in Fargo
