Wood Storage Loft.
Forum topic by Bill Butler posted 614 days ago 184 views 0 times favorited 3 replies Add to Favorites Watch
View Bill Butler's profile
Bill Butler
73 posts in 662 days
614 days ago
Topic tags/keywords: question
I guess this is not technically a woodworking project per se, but I think this is probably the appropriate forum.
Back in February I bought about 550bf of graded select cherry. The actual load from my rough measurement is about 800bf ( The load size is tightly stacked and is 27” x 46” by 8’ ) and it includes portions that didn’t pass for select such as sapwood and bark.
Using a lumber weight calculator I estimate that this is about 2200 pounds.
My garage has an unusual ceiling arrangement. I have 12’ ceilings in my family room which butts up to the garage, and so this feature is carried out into the garage for the first 8’, the remaining 12’ are a more traditional 8’ high.
My wife’s uncle, a retired home builder forman/supervisor, took a look at the construction and made a determination that there is sufficent load bearing members in the right places such that I should be able to rig up a truss that would span the 8’ width of the portion of the garage that has 12’ ceilings giving me a 4’ high by 8’ wide place to store lumber.
We discussed it further and thought that galv piping in the 2” range spaced every 16” like studs would be sufficent to support the weight in theory. I am looking to store most of the cherry up there plus some other wood, so I figure about 2500 pounds.
If I installed 8 2” galv pipes between the two walls every 16” the weight load per pipe would be in the neighborhood of 300#.
Can anyone give me some insight on the load bearing capabilities of galv piping? Do you think it is unreasonable to expect an 8’ span of 2” pipe to support 300# of load?
Thanks a heap.
View GaryK's profile
GaryK
9551 posts in 888 days
613 days ago
I would think that it could handle it. Test it. Get a piece, and you and a friend hang from it to see what it
does.
View DaveH's profile
DaveH
372 posts in 678 days
613 days ago
I’m pretty sure the 2” galvanized pipe will sag under the load. You will probably need steel pipe or square tubing. I did an 8’ closet clothes rod out of 1.5” galvanized pipe and I had to support it at 4’ to eliminate the sag. If you find a good solution, let me know. I have a similar need. I been thinking about using plywood to construct my support beams. My idea is to glue 3 or 4 pieces of 3/4 inch plywood together to make a 3” x 6” x 8’ beam. Haven’t tried it but I’m thinking that it might work. My other thought is to use steel or LVL beams.
-- DaveH - Boise, Idaho - “How hard can it be? It's only wood!”
View Fireball's profile
Fireball
38 posts in 966 days
613 days ago
Bill,
If you send me enough of the cherry the galvanized pipe won’t sag! I’ll PM you my address and you can ship it right off – glad I could help! :)
