reversible glue joint router bit
Forum topic by Jeff82780 posted 06-05-2011 06:52 PM 4472 views 0 times favorited 5 replies Add to Favorites Watch
View Jeff82780's profile
Jeff82780
204 posts in 2961 days
06-05-2011 06:52 PM
Just bought this bit to use on some drawers i plan on makin and I am having a heck of a time. take a look at pics below. For some reason I keep getting some form of snipe when I use the bit. The fence is even and flush with the bit. Its really frustrating . take a look at the first pic.
As you can see on the 2nd pic, I have a gap. I don’t know why? I thought I had everything set up correctly.
Does anyone have experience with this bit? I could really use some help.
Thanks, Jeff
5 replies so far
View sawblade1's profile
sawblade1
754 posts in 2993 days
#1 posted 06-05-2011 07:08 PM
As far as the snipe move your fence out using a feeler gauge till it is flush or slightly passed the center shank of the bit, as far as the gap is concerned using plywood could be part of the culprit, but try raising the bit first
Hope this helps :)
-- Proverbs Ch:3 vs 5,6,7 Trust in the lord with all thine heart and lean not unto your own understanding but in all your ways aknowledge him and he shall direct your path elmerthomas81@neo.rr.com
View JJohnston's profile
JJohnston
1622 posts in 3258 days
#2 posted 06-05-2011 07:37 PM
Source: I’ve used one of these in a shaper before, though I’ve never used one on a perpendicular joint like that, only on panel piece edges.
Because this type of bit removes material from the entire edge, the fence has to be set up like jointer tables. The outfeed face should line up with the end of the little tongue, since that’s what sticks out farthest. This is for the piece you feed flat. For the piece you’re feeding standing up on end, the fence needs to be flush, and high enough that the uncut part of the piece rides on it (above the bit).
As far as the gap, I don’t think this type of bit is intended to do this type of joint (you’ll want a drawer lock bit instead), but you might try lowering it so the shoulder in the piece in your hand is right at the thickness of the perpendicular piece.
-- "A man may conduct himself well in both adversity and good fortune, but if you want to test his character, give him power." - Abraham Lincoln
View Gregn's profile
Gregn
1642 posts in 2950 days
#3 posted 06-06-2011 04:43 PM
As JJ said you need a drawer lock bit for this type of joint. http://mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/bt_door.html#drawer_lock_video_anchor
The reversible glue joint bit is more for edge gluing and not for joinery. You can also use the table saw to make drawer locking joints as well if you don’t want to buy another bit.
http://www.finewoodworking.com/SkillsAndTechniques/SkillsAndTechniquesArticle.aspx?id=30193
View mrg's profile
mrg
818 posts in 2966 days
#4 posted 06-07-2011 05:26 AM
You may want to try a lock joint bit like this.
-- mrg
View childress's profile
childress
841 posts in 3508 days
#5 posted 06-07-2011 09:16 AM
You might want to try to turn your pieces around (if that makes sense) rout the face of the other piece and vice versa. You need them to fit like this, right?
-- Childress Woodworks
