What should be my very first hand plane ?
Forum topic by David Grimes posted 06-05-2011 12:23 PM 4067 views 0 times favorited 121 replies Add to Favorites Watch
View David Grimes's profile
David Grimes
2078 posts in 2542 days
06-05-2011 12:23 PM
What new, inexpensive hand plane should be my first ?
Please don’t tell me to get an old Stanley and restore it. Even if I have to sharpen and flatten the new plane to get it to work, that’s fine. Even if I someday give it away because my future experience tells me it is not worthy to be in my collection.
I just want to know what of the readily available planes (new Stanley or other) that cost $100 or less I should start with and what I can reasonably expect to want to use it for instead of using my power tools.
As always, I do appreciate the advisement and learning I get from responses.
-- If you're going to stir the pot, think BIG spoon or SMALL boat paddle. David Grimes, Georgia
121 replies so far
View saddletramp's profile
saddletramp
1180 posts in 2541 days
#1 posted 06-05-2011 12:47 PM
A block plane. They have a myriad of uses and are fairly easy to employ. Lie-Nielsen makes several in the $100.00 range and Stanleys are less.
-- ♫♪♪♫♫ Saddletramp, saddletramp, I'm as free as the breeze and I ride where I please, saddletramp ♪♪♪♫♪ ...... Bob W....NW Michigan (Traverse City area)
David Grimes
#2 posted 06-05-2011 01:40 PM
If Stanley, the 9 1/2 or the 60 1/2 low angle ? I can get both for under $100. Or should I get one or the other of the new “Sweetheart” versions ? What’s the difference in regular versus sweetheart ?
View knotscott's profile
knotscott
7871 posts in 3278 days
#3 posted 06-05-2011 01:42 PM
Definitely a block plane. It’s hard to beat the quality of a Lie Nielsen or Veritas if you don’t mind spending the full $100 budget. I wouldn’t shell out the money for a new era Stanley or Woodriver made in China. There are a lot of good used or NOS block planes available that don’t need to be restored….
I picked up this NOS Record 60-1/2 for ~ $30.
View mainwoodworks's profile
mainwoodworks
112 posts in 2551 days
#4 posted 06-05-2011 01:51 PM
With out a doubt, the block plane is the most often used plane in my shop.
-- Measure twice, cut once, and hope for the best.
View Don W's profile
Don W
18604 posts in 2470 days
#5 posted 06-05-2011 01:55 PM
I agree with everything said so far, but also you can find the older planes either already restored or are still in good condition. You may save a few bucks that way.
View Tedstor's profile
Tedstor
1643 posts in 2536 days
#6 posted 06-05-2011 02:04 PM
I think a good block plane and jack plane can get a lot of work done.
The newer Woodriver planes from woodcraft seem to get pretty good press. I think the block planes are around $100.
16272 posts in 4121 days
#7 posted 06-05-2011 03:57 PM
I agree with all the advice above.
I’m curious, though, about your not wanting to consider older planes. If you should decide to get anything larger than a block plane, you can save an awful lot of money. Don’t be put off by the restoration process. All the stuff you read about electrolysis and other complicated processes is not really necessary. With a $30 investment in an old plane, a wire brush, sandpaper, and a couple hours of elbow grease, you can have yourself a #4 Stanley that is equal to or better than a new Sweetheart that would run you $179.
View David Kirtley's profile
David Kirtley
1286 posts in 2901 days
#8 posted 06-05-2011 04:35 PM
Remember, a plane is just a jig for holding a piece of steel. There is nothing magical about them.
You might take the plunge and try a wooden plane. They can be had for not too much money and are a pleasure to use. The adjustment is not hard and they feel really nice to use. You can pick up one for $45.
One other option, that I would really say is the better, is to make one. The kit that Ron Hock sells is about $100 and is dead simple to put together. Think of it as a class in plane building. Once you have put one together, making more is cheap and simple. You can make whatever size and configuration you want. Watch his video that shows the assembly:
You can use more of his really nice irons or you can pick up others cheaply. I bought a hand full of irons from Lee Valley that are replacements for the wooden planes that they sell for $8-$12 each and can make new planes whenever I feel like it. If you don’t count the time for glue drying, it takes about 30 minutes. I have made several and it is addictive.
I would add that having an adjustable mouth low angle block plane is a must have tool for general use. Nothing wrong with the the $35 modern Stanley ones.
View WayneC's profile
WayneC
13751 posts in 4000 days
#9 posted 06-05-2011 06:43 PM
As others said, an adjustable mouth low-angle block plane. I own and can recommend the LN below. I also have a bunch of referbished older block planes. If you buy from ebay you have to make sure the plane is complete and not damaged. A big item to consider when adding edge tools to your shop is sharpening. You will need a method of sharpening your tools if you do not already have something in place. Cheapest way to start is using sand paper on a flat surface. This is know as scary sharp. You can google “scary sharp” or search this site. Also you could get a sharpening machine such as a Worksharp 3000.
Lee Valley – $145
http://www.leevalley.com/en/wood/page.aspx?p=32685&cat=1,41182,48942
Lie-Nielson – $165
http://www.lie-nielsen.com/catalog.php?grp=1216
Wood River – 89.95
http://www.woodcraft.com/Product/2080308/30621/WoodRiver-Low-Angle-Block-Hand-Plane-with-Adjustable-Mouth.aspx
ebay
http://cgi.ebay.com/VTG-STANLEY-NO-60-1-2-LOW-ANGLE-BLOCK-PLANE-COMPLETE-NR-/160597928936?pt=LH_DefaultDomain_0&hash=item256461ebe8
http://collectibles.shop.ebay.com/Planes-/13874/i.html?_nkw=stanley+60+1%2F2&_catref=1&_fln=1&_trksid=p3286.c0.m282
WayneC
#10 posted 06-05-2011 06:47 PM
Oh and in response to David’s post about making your own plane, I highly recommend this book
http://www.amazon.com/Making-Mastering-Planes-David-Finck/dp/061527353X/ref=sr_1_1?ie=UTF8&s=books&qid=1307292335&sr=1-1
It not only covers how to make planes, but there are great instructions for setting up and using a block plane.
View SCOTSMAN's profile
SCOTSMAN
5845 posts in 3488 days
#11 posted 06-05-2011 07:51 PM
Charlie I have seen and then done it myself when restoring a hand plane using a a standard flat chisel or plane blade oil stone used to run repeatedly over the sole to flatten and remove rust it works ghreat and can be used on the sides too.messy but worth it as the plane comes up like new you should all try it you too charlie let me know what your feelings are when you try it. Alistair
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3061 days
#12 posted 06-05-2011 08:16 PM
Yep, a block plane. It’s beyond your budget, but I’d consider getting one that also does rabbets. I have, and love, the Lie-Nielsen Rabbeting Block plane. It stays in my shop apron…that’s how much it’s used.
But regardless of the brand or style of block plane, even if it’s a cheap Stanley from Lowes, it can be tuned up to work very well. I think once you get used to the utility of block planes, you’ll feel totally naked without one.
-- jay, www.allaboutastro.com
View Gregn's profile
Gregn
1642 posts in 2886 days
#13 posted 06-05-2011 08:34 PM
I have to echo the block plane as well. Sometimes you can find where they sell block planes and jack planes in a set which would be nice to start out with.
#14 posted 06-05-2011 09:44 PM
Alistair: Sounds like a good idea… I’ll have to try it on my next one!
View sikrap's profile
sikrap
1121 posts in 3262 days
#15 posted 06-05-2011 09:52 PM
For less than $100 you can get a 9 1/2/60 1/2 and a GOOD #5 or #4. Yes, they will be older, but they would be ready to use when you get them. There are several of us that sell older, reconditioned planes.
-- Dave, Colonie, NY
showing 1 through 15 of 121 replies
