Help Locating a Couple Router Bit Profiles
Forum topic by Lovegasoline posted 05-16-2018 11:15 PM 944 views 0 times favorited 4 replies Add to Favorites Watch
View Lovegasoline's profile
Lovegasoline
22 posts in 35 days
05-16-2018 11:15 PM
Ok so I’ve got two profiles on my immediate horizon I need to try and match. I’ve always used simple edge treatments, but I’ve undertaken an insane project of renovating 90 year old beat-out kitchen cabinets and they have a teeny bit of decorative detail.
One profile is for a countertop edge. I’m replacing it with a butcher block top and would like to try and match the profile (I’m not too sure how a profiled edge will look on a butcher block counter top, it seems most butcher block edge profiles are a simple square edge, chamfer, or round over. It’s a small counter near to a double enameled cast iron farm sink). Counter top is just under 1” thick.
Here’s some pics:
Lovegasoline
22 posts in 35 days
#1 posted 05-16-2018 11:23 PM
The other profile is for kitchen cabinet doors. Doors are 1-1/16” thick.
Ideally I’d like to be able to make similarly profiled cope and stick doors.
Another option to have available is to be able to mimic the profile as a molding to use on frame and panel door construction.
Any leads as to where I can locate similarly profiled bits?
I’ve never made cope and stick doors before and am interested in trying it out.
View Rich's profile
Rich
2813 posts in 586 days
#2 posted 05-16-2018 11:48 PM
The stick and cope set will be easy. That’s a standard ogee profile and every company makes one. For the first one, google “door edge router bit” and find one that suits you.
-- No matter how much you push the envelope, it'll still be stationery.
View jerryminer's profile
jerryminer
923 posts in 1438 days
#3 posted 05-17-2018 10:04 PM
The first one looks a lot like this:
Infinity Window Stool Bit
The cope-and stick set you show is similar to this (but the tongue size is different—could be adjusted, or door thickness changed):
Infinity Entry Door Set
Lovegasoline
22 posts in 35 days
#4 posted 05-18-2018 07:14 PM
^ Yep, it’s a window sill bit.
In fact my window sills have this same profile … my kitchen cabinets are built in (1920s) and the builders made everything very efficiently ; )
I still need to check dimensions and profile for the cope and stick profile …
