Dewalt 735 Planer
Forum topic by Jim Finn posted 06-05-2011 03:09 AM 1336 views 0 times favorited 5 replies Add to Favorites Watch
View Jim Finn's profile
Jim Finn
2656 posts in 2917 days
06-05-2011 03:09 AM
Topic tags/keywords: dw735 planer
I have this very nice planer but it has become hard to adjust the height. I have lubricated the threaded posts but it is still very hard to turn the handle to adjust the blade height. The planer cuts well and I like this tool, except for this. Anyone else run into this and found a fix?
-- Website is No PHD just a DD214 and a GED https://craftingcouple.com/
5 replies so far
View ChuckV's profile
ChuckV
3118 posts in 3523 days
#1 posted 06-05-2011 03:27 AM
I have not had that problem with mine. But, if you unplug it and remove the top, as if you were changing the blades, you will see a chain that goes around the four posts. It is like a bicycle chain. Perhaps that needs to be cleaned and/or lubricated.
Good luck.
-- “Big man, pig man, ha ha, charade you are.” ― R. Waters
View gfadvm's profile
gfadvm
14940 posts in 2685 days
#2 posted 06-05-2011 03:36 AM
I dont know about the Dewalt but my Ridgid has a feature to limit thickness. Check to see if youre trying to crank below where the thickness dealie is set. Ive done this repeatedly on my planer.
Jim Finn
#3 posted 06-05-2011 05:10 AM
Thanks Chuck, that did the trick! Seems there is an idler sprocket inside that I could not clean and lubricate without removing the top. I did find a LOT of sawdust in there. I wonder how it got out of the dust collector airstream to accumulate in there. I did notice a chiped blade on the discharge fan but there is ample airflow without the dust collector connected….. and the Dust Collector is working well. It does crank easily now though.
View Joe Lyddon's profile
Joe Lyddon
10096 posts in 4048 days
#4 posted 06-05-2011 07:02 AM
I had that problem once…
It turned out to be the power cord was looped just a little bit to where it stopped the top from going up.
From now on, I make sure the power cord is fully FREE with no hangups.
ChuckV
#5 posted 06-05-2011 02:24 PM
Jim – I’m glad to hear that you are cranking again!
