Retractable casters
Forum topic by RobHannon posted 05-16-2018 07:18 PM 559 views 0 times favorited 6 replies Add to Favorites Watch
View RobHannon's profile
RobHannon
145 posts in 649 days
05-16-2018 07:18 PM
I have been brainstorming how I want to design my workbench and as much as I want it to be fixed I don’t see any way I can swing that without getting rid of tools or moving into a larger shop. So I have been looking into how I can make it mobile when needed and very stable when where I want it. Looking at the retractable casters that are made for both workbenches and mobile bases, they all seem to use fairly small diameter wheels. While I am sure cost is a significant factor in that design, is there some reason a larger wheel wouldn’t work?
Small wheels in my shop are not usable so I don’t think the retail ones would work, but I’m not against reinventing the wheel with bigger parts. Also seriously considering building it with some clearance and getting a used pallet jack.
View Loren's profile
10477 posts in 3766 days
#1 posted 05-16-2018 07:38 PM
Smaller casters pivot on a smaller radius so
in circumstances where you have to mount an
outrigger support to attach the caster to it
doesn’t have to protrude as far.
View MrUnix's profile
MrUnix
6889 posts in 2317 days
#2 posted 05-16-2018 08:45 PM
I made one with a bigger caster… once you start looking at the design, you will understand the wheel size (and weight) limitation on those smaller ones.
Instead, you might want to try to incorporate a pivoting hinge type where the casters are mounted on a 2×4 or similar that is hinged. Here is a good example of one such design by Mattias over at woodgears: Mobile jointer base
There are a few other similar types that are floating around here on LJ’s, as well as plenty others that can be found with a quick google.
View Breeze73's profile
Breeze73
94 posts in 800 days
#3 posted 05-16-2018 10:24 PM
I used hockeypucks with bolts going through mine to allow the bench to be leveled up behind my table saw as an outfeed table. I then put the Rockler flip down castors to allow mine to be mobile. However, I replace the 2” castors in the Rockler set with 4” castors to get a better weight rating. My 430lb bench moves with ease now. http://lumberjocks.com/projects/329057
-- Breeze
View fuigb's profile
fuigb
506 posts in 3076 days
#4 posted 05-16-2018 10:54 PM
For a down and dirty bench for my garage I put casters on one end only: legs on the wheeled end are cut shorter by the amount necessary to achieve a level surface. On the sides of the end without wheels I mounted steel brackets of the sort that one would use for barring a door with 2×4s. When I need to move the bench I slip lengths of 2×4 into the brackets and then lift and move as one does a wheel barrow. Not a job for the weak, lazy, or old but this bench is as solid as hell and is mobile enough that I can move it into the driveway.
-- - Crud. Go tell your mother that I need a Band-aid.
RobHannon
#5 posted 05-17-2018 12:49 PM
- Breeze73
I was thinking of that but didn’t think the larger wheels would clear the mechanism. Do you happen to have a pic of them?
View Kelly's profile
Kelly
2073 posts in 3063 days
#6 posted 05-17-2018 04:26 PM
I used the ones Rockler sells and has regular sales on for my bench. It has reasonably sized casters.
The good sales tend to be months between, but I got my set for forty. Otherwise, they run sixty, but are still a good buy, if you need them.
http://www.rockler.com/workbench-caster-kit-4-pack
