planer issue
Forum topic by mike123789 posted 05-16-2018 02:08 PM 436 views 0 times favorited 7 replies Add to Favorites Watch
View mike123789's profile
mike123789
14 posts in 575 days
05-16-2018 02:08 PM
I have the Rigid 13 inch planer and I like making end-grain cutting boards. My problem is, after milling is done and all the boards are beautiful and done with the first glue up, I plane again to flatten from inconsistency in wood height from clamping and after I make my cross cuts I notice my boards have gaps between because the planer left “birdbath” cups and divots throughout my board. Is this a common problem?
7 replies so far
View TechTeacher04's profile
TechTeacher04
389 posts in 1646 days
#1 posted 05-16-2018 02:14 PM
Do you have any pictures? I am uncertain which side the cupping it on.
mike123789
#2 posted 05-16-2018 02:48 PM
“cupping” may not be the best word as it is easily associated with board warp. basically when i cross cut and go to fit the boards together there are some pretty extreme gaps especially in the center. but its not consistent through the board. I have no pictures at present
View John Smith's profile
John Smith
1306 posts in 277 days
#3 posted 05-16-2018 03:06 PM
Mike – are you actually running a finished glued up end grain board through your planer ?
-- some people are like a Slinky - - - pretty much good for nothing. But still make you smile when you push them down a flight of stairs.
View pintodeluxe's profile
pintodeluxe
5738 posts in 2928 days
#4 posted 05-16-2018 03:11 PM
If you are talking about scalloping or many shallow troughs left behind on the workpiece, then I think it is just a result of trying to plane end grain with straight knives. The stars have to align for that to go right. Some people get away with it, but only under certain conditions.
- brand new sharp knives
-or better yet, helical head
-waxed planer be
-extremely light cuts (remove next to nothing per pass)
I think a drum sander or ROS is a better tool for the job.
mike123789
#5 posted 05-16-2018 03:40 PM
- John Smith
No John, this is planing the edge grain before the crosscut glue up. i learned my lesson planing end grain
View diverlloyd's profile
diverlloyd
3008 posts in 1972 days
#6 posted 05-16-2018 04:26 PM
Glue some staringht boards to the sides then put it through the planer.
View bbasiaga's profile
bbasiaga
1240 posts in 2109 days
#7 posted 05-16-2018 04:58 PM
If your plane is leaving a scooped or scalloped surface it might be because one of the blades protrudes a little more than the other. Also I think two knife planers are worse about this than 3 knife models.
Stil,it should be so mistaken jet you can’t see them in the joint. Pics will help.
Brian
