cl jointer
Forum topic by ryan posted 06-04-2011 03:53 PM 1113 views 0 times favorited 5 replies Add to Favorites Watch
View ryan's profile
ryan
21 posts in 2464 days
06-04-2011 03:53 PM
Topic tags/keywords: jointer
Just thought I would post some pics of my jointer than I got on craigslist for a 100 dollars. The guy selling this got a 8 inch jointer and was selling his six inch because he did not have space for both. It is a 1980 craftsmen jointer. What I was wondering if there is an easy way to enclose the base to contain the shavings because right now they are getting all over.
5 replies so far
View rsdowdy's profile
rsdowdy
105 posts in 3104 days
#1 posted 06-04-2011 04:34 PM
Nice score for 100.00! Make and angled wood frame to go under there?
Royal
View Bluepine38's profile
Bluepine38
3379 posts in 2993 days
#2 posted 06-04-2011 07:03 PM
Do not try to enclose the entire base, your electric motor would get full of dust and chips! If you check
the bottom of the jointer, there should be some way to adapt hose end similar to the Grizzly-G2977 to
the jointer. I did this with a Delta jonter and a shop vac pulls all the output from the jointer with no
problem.
View SCOTSMAN's profile
SCOTSMAN
5845 posts in 3493 days
#3 posted 06-04-2011 08:45 PM
A good deal you can hardly buy a hand held one for that kind of dough. Alistair
View Grandpa's profile
Grandpa
3259 posts in 2583 days
#4 posted 06-04-2011 09:52 PM
For years I used a cardboard box that my big tool box came in. I could slide it out and empty it then put it back. Try making an inverted roof out of flashing material. You can put it together with screws. The shavings will slide down to the bottom and a vacuum can be attached to the side. As Bluepine said you need to keep the chips out of and away from the motor.
View superstretch's profile
superstretch
1531 posts in 2601 days
#5 posted 06-05-2011 11:59 PM
You could drill some holes and pop rivet some sheet metal there. You might find a DC hood for that model… run it to a chip collector and you should be set.
-- Dan, Rochester, NY
