Electric Hand Planer
Forum topic by JCamp posted 05-15-2018 12:54 PM 642 views 0 times favorited 15 replies Add to Favorites Watch
View JCamp's profile
JCamp
797 posts in 671 days
05-15-2018 12:54 PM
I believe a electric hand planer is next on my “to buy” list. My reasoning is that I can quickly use it to knock down the high spots prior to running boards through my bigger Dewalt planer.
I’ve been looking for a while and I believe I’ve narrowed it down to 4.
1- porter cable 6amp $70
2- black and decker 5.2 amp $64
3- harbor freight 7.5 amp $60
4- harbor freight 5.5 amp $38
All are 2 blade and 3.25 inches wide.
I know there are probably some better ones but I currently don’t think that I’ll use it enough to spend over a $100 on it.
Any thought or suggestions?
And yes I do have hand planes but since I moved last fall my “work bench” is my tablesaw so it would b hard to use them
-- Whatsoever thy hand findeth to do, do it with all thy might
15 replies so far
View Jeff's profile
Jeff
467 posts in 3315 days
#1 posted 05-15-2018 12:59 PM
I have a Hitachi branded power plane. The only use it ever got was to plane down the edge of a door to make it fit. It is very difficult to control over a wider surface. I’ve used my tablesaw as a work surface. It’s easy to clamp items down to prevent moving.
View rwe2156's profile
rwe2156
3073 posts in 1601 days
#2 posted 05-15-2018 02:29 PM
What kind of wood are you working with? I’ve never had to do that if I get a board with unevenness, I just run it thru the planer a few times until its planed off.
I have a Bosch collecting dust somewhere. Seems to work pretty well.
I would definitely take a look at Ryobi. $80.
View John Smith's profile (online now)
John Smith
1312 posts in 283 days
#3 posted 05-15-2018 02:41 PM
having the choice of directing the chips is a big plus.
I don’t know if the late models have an “adjustable” chip deflector, but something to consider.
I like the idea that I can direct the chips to one side or the other.
I have had this old vintage Skil hand plane for 40 years and it has a simple deflector.
-- some people are like a Slinky - - - pretty much good for nothing. But still make you smile when you push them down a flight of stairs.
View RobHannon's profile
RobHannon
148 posts in 651 days
#4 posted 05-15-2018 02:47 PM
I have an old Ryobi (when they were blue) that was great for adjusting doors, but not what I would call a versatile tool. A belt sander with a coarse belt is what I turn to for quick removal of high spots.
View CharlesA's profile
CharlesA
3339 posts in 1918 days
#5 posted 05-15-2018 02:55 PM
I bought a makita for a specific job and it was fabulous. I haven’t used it since then, but I will have no hesitancy if the need arises. It can produce a mountain of chips.
View waho6o9's profile
waho6o9
8362 posts in 2697 days
#6 posted 05-15-2018 03:09 PM
Just for the heck of it
70 + 64 + 60 + 38 = 232. Divided by four = 58
So the 60.00 7.5 amp Harbor Freight planer gets my vote.
JCamp
#7 posted 05-15-2018 03:54 PM
Thanks for the advice so far. I’ll take a look at the Ryobi.
I should hav said that I’m mostly working with maple, ash and white/red oak at this point. Some of the boards are bowed a good bit. Seems to take forever getting them flat with only the big planer. I figured the hand planer would do fast work and then use the big one at the end. I do also have hand held belt sander but that seems like it would take a while too.
I had considered just buying the cheaper HF one then seeing how much I used it. If I used it a lot and it crapped out I could go get a nicer one at that point
View PPK's profile
PPK
1122 posts in 930 days
#8 posted 05-15-2018 04:31 PM
View BurlyBob's profile
BurlyBob
5897 posts in 2386 days
#9 posted 05-15-2018 05:45 PM
I bought a Makita several years ago. Nothing really wrong with the tool. It works just fine. I still consider it a waste of money. In the 10 years since, I’ve used it once, that first time. All it does is sit in a box under my bench.
View torus's profile
torus
145 posts in 533 days
#10 posted 05-15-2018 05:53 PM
WEN 6528 3.8-Amp Electric Hand Planer
https://www.amazon.com/WEN-6530-Electric-Planer-4-Inch/dp/B079FBDPF4
3 sizes from $30 to $50. I use $30 version to flatten one side of firewood logs before ripping them on
the table saw.
Works great and fun to use.
-- "It's getting better..." - put this on my RIP stone!
View Tennessee's profile
Tennessee
2880 posts in 2635 days
#11 posted 05-15-2018 05:59 PM
Back in 1999-2000, when I was restoring a huge farmhouse, I found myself needing one, so I went for the HF model at the time.
It even came in Hitachi green.
Came with an extra set of blades and a funky little do-dad that was used to align the blades when putting them in. Used it for a lot of door edging. Worked OK, save it will dig in on open planks. Be careful! Still runs well today, although I don’t use it much at all.
I’d vote for the $60 Harbor Freight – looks a lot like my old HF save it is now that famous Chicago Electric maroon and black.
View ralbuck's profile
ralbuck
5006 posts in 2387 days
#12 posted 05-15-2018 10:33 PM
As I have had several different brands of electric tools over many decades of tool buying; I have NEVER been disappointed with Bosch anything! i cannot say the same about any of the rest.
-- Wood rescue is good for the environment and me! just rjR
View mel52's profile
mel52
532 posts in 385 days
#13 posted 05-16-2018 01:19 AM
I have a WEN that I ordered from HD, that I like. It also has a switch that deflects chips to either side. Wasn’t that expensive either.
-- MEL, Kansas
woodbutcherbynight
5545 posts in 2529 days
#14 posted 05-16-2018 02:48 AM
T
- JCamp
I have used this method a few times. As you said if you use it and like it you can always get a upgrade. Or if it is not what you thought it would be you still have a quick planer for odd jobs, like doors.
rwe2156
#15 posted 05-16-2018 02:09 PM
- JCamp
Might be appropriate to make sure the terminology is correct.
A bow is curved along the flat length of a board.
A cup is across the width.
A warp is along the edge.
Assuming a jointer isn’t an option, there are various type of jigs and sleds you can use in your planer to remove the cup.
