Jointer-- lower knife height or raise outfeed table height
Forum topic by ppg677 posted 05-14-2018 02:47 PM 964 views 0 times favorited 15 replies Add to Favorites Watch
View ppg677's profile
ppg677
209 posts in 1092 days
05-14-2018 02:47 PM
Hi, I recently changed blades on my old Boice-Crane 6” jointer. While I borrowed a jointer pal device from a friend and followed the instructions, I’m getting snipe about 1.5-2” at the end of the board. Thus it seems my knives are set a tad too high relative to the outfeed table.
Should I look to lower the knife height or raise the outfeed table? I tried making a DIY jointer pal using magnets glued to a p;iece of wood but am skeptical it is accurate/flat enough (I did sand it with a sheet of sandpaper on a cast iron flat table saw top).
As far as raising/lowering the outfeed table, I’m not sure how to do that. There is a knob very similar to the infeed table knob (which works very smoothly), but this knob seemingly just loosens/tightens a bolt and doesn’t actually move the outfeed table. Is the idea to loosen this knob and manipulate outfeed table height with dead blows from a mallet or something?
15 replies so far
View rwe2156's profile
rwe2156
3230 posts in 1716 days
#1 posted 05-14-2018 03:02 PM
There’s a reason why outfeed tables are adjustable :-D
View Dustin's profile
Dustin
611 posts in 976 days
#2 posted 05-14-2018 04:34 PM
If your outfeed table isn’t adjusting with the knob, I’d be looking for gib screws on the outfeed side. They may be tightened down too much to allow movement (though I don’t see any in the photo).
-- "Ladies, if your husband says he'll get to it, he'll get to it. No need to remind him about it every 6 months."
View MrUnix's profile
MrUnix
7106 posts in 2435 days
#3 posted 05-14-2018 05:49 PM
As far as raising/lowering the outfeed table, I m not sure how to do that. There is a knob very similar to the infeed table knob (which works very smoothly), but this knob seemingly just loosens/tightens a bolt and doesn t actually move the outfeed table. Is the idea to loosen this knob and manipulate outfeed table height with dead blows from a mallet or something?
- ppg677
No… the adjustment knob for the outfeed table works exactly the same as it does for the infeed table. Here are what they look like with the tables removed:
If yours isn’t moving the table, then something is wrong and you need to get under there and look to see if you can figure out why.
PS: To set the knives, get a dial indicator if you don’t already have one… about $30 for a set off amazon with a magnetic base and 20+ different tips for multiple applications.
View chrisstef's profile
chrisstef
17798 posts in 3242 days
#4 posted 05-14-2018 05:53 PM
What Dustin said. Check for allen head bolts on the rear of the outfeed table.
View AlaskaGuy's profile
AlaskaGuy
4986 posts in 2545 days
#5 posted 05-14-2018 09:54 PM
What brad said about getting a dial indicator to set knifes.
My preference is a non magnetic so I can easily slide it across the table.
View Rich's profile
Rich
3993 posts in 825 days
#6 posted 05-14-2018 11:12 PM
Yes, and that foot is broad enough to turn the head back and forth to see top dead center. The blade just glides across it. I have the same gauge and it’s a perfect example of a situation where a dial indicator beats digital hands-down.
ppg677
#7 posted 05-15-2018 03:04 PM
Thank you all. The outfeed table now moves after I got some WD-40 in there. Turns out it is in the max height position and the blades are bottomed out…because the new blades (6” x 5/8×1/8) I ordered are a wee bit too tall. Guess I’ll take them to the grinder and see if I can shorten them up a tad.
MrUnix
#8 posted 05-15-2018 04:35 PM
...because the new blades (6” x 5/8×1/8) I ordered are a wee bit too tall. Guess I ll take them to the grinder and see if I can shorten them up a tad.
- ppg677
That is the correct size knives, so you may want to investigate a bit further. The Freud C350 set fits perfect without any modifications necessary, and IIRC, there was still plenty of travel up/down on the outfeed table.
ppg677
#9 posted 05-16-2018 12:59 AM
To investigate further implies I should figure out how to get the outfeed table removed. Should I be able to keep turning that knob counterclockwise lowering until the table just comes off? It lowers quite a bit and then stops. Not obvious how to remove the knob.
View onoitsmatt's profile
onoitsmatt
407 posts in 1412 days
#10 posted 05-16-2018 01:56 AM
I have nothing to contribute but threads like this is why i love LJs.
Brad, you’re a national treasure.
-- Matt - Phoenix, AZ
MrUnix
#11 posted 05-16-2018 04:13 AM
- ppg677
The table is held in place by one bolt, as I showed in your thread over at the OWWM site (and posted again here below). Remove it and the table will come right off. Give the ways a good cleaning and then wax or otherwise lubricate them so they slide easily. The table should be able to raise well above and below the cutterhead.
ppg677
#12 posted 05-16-2018 01:55 PM
Ah, the bolt was on the bottom. Oops!
I figured it out. The spacers on the knob were on the wrong side. Thanks! This is a nice little jointer I scored for $50 a couple years ago.
MrUnix
#13 posted 05-16-2018 05:49 PM
They are nice little jointers and built rock solid. I got mine as a package deal along with a Delta 14” band saw for $170 – so figure $85 if you split the cost in half. Although mine also came with the original flare leg stand, motor and wiring. They do clean up nice:
Just for grins, here is what one looks like exploded :)
ppg677
#14 posted 09-04-2018 03:12 AM
So now my outfeed table goes up and down easily, but it won’t stay set in a position. It gradually lowers with use. Hmm…
View TheFridge's profile
TheFridge
10815 posts in 1722 days
#15 posted 09-04-2018 12:19 PM
I didn’t look but I’m willing to bet it should have gib locks
