Lumber choice for outdoor dining table
Forum topic by ArmchairLinebacker posted 05-13-2018 11:37 PM 1637 views 1 time favorited 34 replies Add to Favorites Watch
View ArmchairLinebacker's profile
ArmchairLinebacker
7 posts in 131 days
05-13-2018 11:37 PM
Topic tags/keywords: outdoor furniture finnish hardwood deck patio question
Hi,
Relative newbie here. I want to build an outdoor dining tale for my backyard. I saw an amazing teak table and chairs at Costco for about $2800 that is kind of my inspiration.
I did some quick math and figured I could build the table out of teak for about $900 (90 board feet). Im not sure if thats accurate now or not. But I went home and whipped up a design on Sketchup based on 2X6 construction.
I have watched woodworking videos for years starting with pretty much every New Yankee Workshop episode and more recently YouTube videos by Jon Peters etc. In December I finally moved to a place where I could set up my own shop. I have a Delta 36-725 table saw, an old Hitachi 6.5 miter saw and just bought a 10” craftsman Radial arm saw.
I am wondering if i should
A) Make this table out of construction grade softwood and deck stain? Like a picnic bench
B) Try to source teak in 2X6
C) Make a solid hardwood top
I don’t know about the top being either slats with gaps or without or maybe a solid top with an epoxy finish. Just don’t know about what is necessary or realistic for outdoor furniture.
34 replies so far
View jmartel's profile
jmartel
8121 posts in 2266 days
#1 posted 05-13-2018 11:40 PM
I want to know where you are going to be getting 8/4 teak for $10/bdft. 4/4 is $28/bdft here.
View Runner's profile
Runner
69 posts in 889 days
#2 posted 05-13-2018 11:58 PM
I’m building something similar in the near future. Planning on using Menards’ rough sawn cedar. It’s about $2.2 bft. My only concern is the moisture content which is about 11%. Does anyone know if this is too high to start an outdoor table?
-- Kjell - Eau Claire WI
View jonah's profile
jonah
1837 posts in 3415 days
#3 posted 05-14-2018 12:45 AM
Unless you’re made of money, I’d never build anything meant for outdoors out of expensive wood. The sun does a number on wood, even wood that is taken care of with stain, paint, or clear finishes.
I’d use cedar or something similar. It’s relatively cheap and it holds up as well as anything outside. Use an exterior stain or clear finish and plan on reapplying often (yearly, most likely).
View John Smith's profile
John Smith
1308 posts in 279 days
#4 posted 05-14-2018 12:55 AM
since you are relatively new to woodworking, why don’t you build a table
of your design with pressure treated construction lumber to practice with
before you invest a lot of money into something that may not serve you well.
let it air dry a few weeks before applying a stain – it will still look good.
-- some people are like a Slinky - - - pretty much good for nothing. But still make you smile when you push them down a flight of stairs.
ArmchairLinebacker
7 posts in 131 days
#5 posted 05-14-2018 02:03 AM
You guys are awesome, thanks I think i’ll take your advice and use construction grade softwood with a seal/stain.
Should I make the feet, or legs, or entire bottom out of pressure treated? Or is that not necessary? Table will be on an uncovered concrete patio.
Also as far as the top goes, should i leve room between the wooden slats, butt them up against each other, or attempt a glue-up to make a solid top?
woodbutcherbynight
5545 posts in 2525 days
#6 posted 05-14-2018 02:44 AM
- ArmchairLinebacker
My suggestion would be to keep this 1st project bare bones simple. Use pressure treated for entire project. 2×6 for top butted with small gaps. (these will open over the years with the weather and drying process) That done finish as you like and enjoy. As the years go by you will see where improvements can be made.
View Woodknack's profile
Woodknack
12331 posts in 2496 days
#7 posted 05-14-2018 02:56 AM
since you are relatively new to woodworking, why don t you build a table
of your design with pressure treated construction lumber to practice …
- John Smith
This is good advice. Your first piece will not be your best piece no matter how prepared you feel. There are plenty of rot resistant woods like white oak, mahogany, teak, walnut, cedar and cypress heartwood (must be heartwood), and many others you can google. Look at what is used for decking in your area. I’m not crazy about your design either. I would want the battens turned on edge and connected directly to the legs.
View BFamous's profile
BFamous
156 posts in 237 days
#8 posted 05-14-2018 02:57 AM
I made my outdoor table out of cedar about 5 years ago…cost me about $400 for the materials to make a behemoth 4 ‘x 12’ table.
About twice a year I use a scotchbrite pad and soapy water to clean it, then reapply teak oil. So far it has held up and aged beautifully.
Not the best picture of the table, but this is from last fall. I think the cedar just gets better looking with age.
Also, I wouldn’t want to eat anything off of a table made from pressure treated wood. I’d at least do a cedar top if you’re going to do it out of pressure treated…
-- Brian Famous :: Charlotte, NC :: http://www.FamousArtisan.com
jmartel
#9 posted 05-14-2018 03:30 AM
I’d make the whole thing out of cedar instead of pressure treated, personally. Leave room between the slats for water to drain. If you really want to make it to last, put some epoxy on the bottom of the legs and anything touching the ground.
View Rich's profile (online now)
Rich
3525 posts in 706 days
#10 posted 05-14-2018 04:05 AM
I would definitely make mine out of ebony.
View Aj2's profile (online now)
Aj2
1656 posts in 1914 days
#11 posted 05-14-2018 01:49 PM
I made my outdoor table out of cedar about 5 years ago…cost me about $400 for the materials to make a behemoth 4 x 12 table.
Also, I wouldn t want to eat anything off of a table made from pressure treated wood. I d at least do a cedar top if you re going to do it out of pressure treated…
That’s a nice looking table.
If that’s your back porch I’m pretty sure I’m going to hate you.:)
- BFamous
-- Aj
View rwe2156's profile
rwe2156
3069 posts in 1597 days
#12 posted 05-14-2018 02:35 PM
I would go with cedar or cypress.
Keep in mind with cedar the sapwood will rot.
View jamsomito's profile
jamsomito
202 posts in 542 days
#13 posted 05-14-2018 03:10 PM
I have an outdoor table and benches lined up for my next project. I really wanted to do cedar but it just wasn’t in the budget so I wound up with pressure treated southern yellow pine. I don’t like that I have to work with chemically treated material, and yes, you don’t want to eat food that comes in contact with the stuff either. But, it will last a long time, it’s cheap, and I figure a good opaque stain will be a good enough barrier to be safe to sit around and eat at. Plus, when was the last time you ate potato salad directly off the table top? We’ll be using plates. And we will probably use it a couple times a week for only a few months a year. I’m pretty sure it will be fine.
I bought the lumber last year. I got KDAT (kiln dried after treatment) wood, but it was still sopping wet. I put it on stickers on the lumber rack last summer, so it will have been almost a full year now when I start working with it. You probably don’t need to wait that long, but I got busy and now I’m sure it will be as dry as needed. Some of it did twist, especially the 4×4’s I got. Not sure how I’m going to deal with that yet, but I’m glad it’s dry at least.
jonah
#14 posted 05-14-2018 03:18 PM
I would not make a table I intend for people to eat off of out of pressure treated lumber. If you must, you can make the base out of it, but the top should be something nontoxic. Even modern pressure treating uses foul chemicals (although no arsenic, so progress) that you absolutely do not want to come into direct contact with. If you’re going the big box SPF route, just get some regular 1×5 stock to make the top out of.
View jbay's profile (online now)
jbay
2583 posts in 1015 days
#15 posted 05-14-2018 03:45 PM
if you are going to The Big Box store, I would just use the Redwood
showing 1 through 15 of 34 replies
