Equipment SAFETY tips: The Hand Plane
Forum topic by MsDebbieP posted 06-03-2011 10:42 AM 5457 views 0 times favorited 9 replies Add to Favorites Watch
18615 posts in 4066 days
06-03-2011 10:42 AM
Topic tags/keywords: safety gateway plane
Safety in the shop tips for the hand plane
What are some tips to work safely on and around a hand plane?
(See all SAFETY TIP GATEWAYS here)
9 replies so far
View mafe's profile
mafe
11631 posts in 2995 days
#1 posted 06-03-2011 02:26 PM
Keep your iron as sharp as possible, most accidents happen when people try and force things.
Stand in a good position and let your body do the work not just the arms.
Best thoughts,
Mads
View dbray45's profile
dbray45
3310 posts in 2682 days
#2 posted 06-03-2011 03:01 PM
Handling the blade. After spending time sharpening and your hands get tired, you really don’t want to drop the blade and cut your leg or foot. May not want ot drop the plane on your foot either.
Thats when other people need hearing protection.
-- David in Damascus, MD
View DaddyZ's profile
DaddyZ
2475 posts in 2946 days
#3 posted 06-03-2011 03:04 PM
ON small boards you should always use a clamp to hold them, Not your hands.
Never put your Hands in line with the blade.
View WayneC's profile
WayneC
13751 posts in 4003 days
#4 posted 06-03-2011 10:45 PM
Don’t drop the plane on your big toe…. Damn. David already got it. : ^ )
There is a serious possibility of becoming addicted.
Also the danger of your wife, husband or signficant other finding out how many you have purchased and at what cost. They could seriously injure you.
View stefang's profile
stefang
15784 posts in 3240 days
#5 posted 06-08-2011 01:49 PM
When testing your plane blade for sharpness, be sure to take it out of the plane before shaving your arm with it (unless you are shooting for a dead flat arm).
View mafe's profile
mafe
#6 posted 06-08-2011 01:52 PM
Mike I suggest you stay in the garden… Laugh.
Best thoughts,
Mads
View HorizontalMike's profile
HorizontalMike
7747 posts in 2819 days
#7 posted 07-19-2011 03:24 PM
I have found that the tool trays on my workbench allow me to keep the plane upright and with the blade down when temporarily not in use, WITHOUT setting the plane on the blade. I just span the plane over the tool tray opening.
When I had laid the planes down on their sides I have managed to accidentally slice one of my knuckles open when I banged up against the blade when using another tool. Lacking a tool tray, it would be easy to make a simple plane stand with a slot wide enough to hold the blade off the surface of your bench/work-piece while on/at the bench for use. Two scrap boards can even do it in a pinch.
View Dan's profile
Dan
3630 posts in 2786 days
#8 posted 10-25-2011 11:16 PM
If the mouth in the plane gets clogged with shavings don’t turn it over and pull them out with your fingers. I did this the other day when some shavings got stuck and I got a nice little slice on my finger tip.
-- Dan - "Collector of Hand Planes"
View Bernie's profile
Bernie
422 posts in 2742 days
#9 posted 10-30-2011 04:39 AM
#1 rule, like mafe said – keep the sharp. I was a Scoutmaster for 20 years and always taught the boys to use sharp knives. Dull ones are the most dangerous tools.
Then you need to keep them sharp like Mike explains.
A 3rd point is to properly set the blade. I always had a hard time doing this until a friend showed me the right way. Take a sheet of paper out of your printer and set your plane on it so the blade falls off the edge of the paper (heel of plane on the paper). The thickness of a sheet of paper should be the right height for the blade in your plane to do fine work. If that’s not enough for you, try 2 sheets of paper etc. etc.
-- Bernie: It never gets hot or cold in New Hampshire, just seasonal!
