How to tell when carbide turning tools are dull
« back to Woodturning forum
Forum topic by Lookwow posted 05-13-2018 12:17 AM 1594 views 0 times favorited 9 replies Add to Favorites Watch
View Lookwow's profile
Lookwow
5 posts in 255 days
05-13-2018 12:17 AM
I know this seems like a stupid question. But I have a hard time telling.
9 replies so far
View Mark's profile
Mark
984 posts in 2215 days
#1 posted 05-13-2018 12:28 AM
When you tool doesn’t make a clean cut (more dust than usual).
When you find your pushing or forcing the tool, it’s off to the grinder.
JMTCW
-- Mark
View TheDane's profile
TheDane
5576 posts in 3903 days
#2 posted 05-13-2018 12:46 AM
... it’s off to the grinder.
I don’t think I would take a carbide tool to the grinder. Maybe touch it up with a diamond plate instead.
I have a couple of carbide tools … they never get dull because I avoid using them.
View Nubsnstubs's profile
Nubsnstubs
1435 posts in 1970 days
#3 posted 05-14-2018 03:51 AM
I’ve always heard from my sharpening services that if you can see the edge, it’s dull…...Jerry (in Tucson)
View rwe2156's profile
rwe2156
3235 posts in 1721 days
#4 posted 05-14-2018 02:46 PM
Lets see, increased feed pressure, more tear out.
If you seen burn marks, it needed sharpening 6 months ago…...
ALWAYS have your carbide blades and router bits sharpened professionally. A grinder will bolux it up and a nano second.
View LesB's profile
LesB
1924 posts in 3684 days
#5 posted 05-15-2018 12:23 AM
Some small tools like router bits can be touched up a time or two with a diamond sharpener but for the most part it is best to take them to a sharpening shop; especially saw blades. A good saw blade can usually be sharpened at least 3 times and if there is a broken or chipped tooth the shop can usually braze on a new one. It takes a lot of practice to sharpen a carbide planer blade so I wouldn’t even try although in a pinch you might make light passes along the straight back edge with a very fine diamond sharpene rto tune it up a little.
As stated previously if it takes more pressure to make a cut, if the cut is rough, of you can actually see light reflect off the edge it is time to sharpen them. You can also educate your fingers to feel for sharpness. The human finger is sensitive to 1/10,000 of an inch. Just compare a new sharp edge to your worn one to see the difference. Keep some bandages handy….LOL
-- Les B, Oregon
View Richard Lee's profile
Richard Lee
213 posts in 1016 days
#6 posted 05-15-2018 01:37 AM
Lightly drag youre fingernail across the edge,it should make shavings.
I agree with Nubsnstubs , if you see a slight reflection from the edge its dull.
View LeeMills's profile
LeeMills
629 posts in 1542 days
#7 posted 05-15-2018 02:43 AM
Here is a good video on sharpening carbide cutters. I do basically the same.
https://youtu.be/uX3UYi0XhK4
Here is a video on what to look for in the diamond plates. It may be an ad but I think it is correct.
https://youtu.be/zBND6emsSE4
I bought some cheapies that did not last long but my good one (over $30 back in the 80’s) is still going strong.
View Sparks500's profile
Sparks500
207 posts in 571 days
#8 posted 05-17-2018 12:19 PM
Dullness can creep up on you. Years ago I bought a Forrest 10” standard blade and was amazed at how well it cut. As time went on, and I was still working, so the shop was only used occasionally, the blade got dull, but with a 3HP Powermatic saw, I didn’t notice.
Got to where I was going to work on a pretty nice project and finally inspected the blade: 5 teeth MISSING, and all the rest looking pretty rough. I felt like an idiot for letting it get so bad, but, I packaged it up, sent it back to Forrest, and, $90 later I had a blade cutting better than new.
I’m the one that’s dull…...
Needless to say, I pay more attention now…...
-- A good day is any day that you're alive....
View MrRon's profile
MrRon
5277 posts in 3484 days
#9 posted 05-17-2018 05:54 PM
Dullness can creep up on you. Years ago I bought a Forrest 10” standard blade and was amazed at how well it cut. As time went on, and I was still working, so the shop was only used occasionally, the blade got dull, but with a 3HP Powermatic saw, I didn t notice.
I m the one that s dull…...
- Sparks500
Replacing 5 teeth is what costs. Fortunately I have carbide saw sharpening equipment (Foley) that I use to maintain all my own carbide sharpening needs.
