Kingsplor Abrasive Disks... Which to Choose?
Forum topic by RPhillips posted 05-12-2018 02:19 PM 1998 views 0 times favorited 10 replies Add to Favorites Watch
View RPhillips's profile
RPhillips
1244 posts in 2078 days
05-12-2018 02:19 PM
I’m about to pick up some Kingsplor abrasive disks for my Bosch ROS65 and I have no clue which type of abrasive is best for woodworking. Which all the choice, I’m lost.. Stearate, Stearate Latex, Stearate A/O, Heavyweight, Lightweight, etc…
Any recommendations where to start?
-- Rob - Indianapolis IN - Learning... one mistake at a time...
10 replies so far
View John Smith's profile
John Smith
1555 posts in 404 days
#1 posted 05-12-2018 02:29 PM
buy a small pack of each to experiment with for the type of work you will be doing.
some woods behave differently when sanded.
-- I started out with nothing in life ~ and still have most of it left.
View EarlS's profile
EarlS
2134 posts in 2590 days
#2 posted 05-12-2018 02:51 PM
To add to John’s comment….Most brands will have a variety pack of grits that will give you an idea of which ones you are most likely to use.
RPhillips
#3 posted 05-14-2018 10:15 PM
Appreciate the comments and I thought about the variety packs, but I would rather get a buy a few packs that work well for woodworking right off the bat. I have bought the “mystery boxes” in the past and been pretty well please with what I received, so I may pick up one or two anyways.
Anyone using Kingsplor H&L disks?
View Redoak49's profile
Redoak49
3744 posts in 2230 days
#4 posted 05-14-2018 11:09 PM
I use the Klingspor Gold disks and very satisfied. I have them from 80 -320 grit.
RPhillips
#5 posted 05-15-2018 11:33 AM
I linked the discs below that I’m thinking of ordering… also believe it’s the same one’s Redoak is referring to.
https://www.woodworkingshop.com/product/vd70040/
50 pk puts the cost at about .36 a disc. not bad.
Thanks for the feedback.
View wncguy's profile
wncguy
421 posts in 2554 days
#6 posted 05-15-2018 12:19 PM
You might want to check out Industrial Adhesives to see their offerings & prices. I’ve used them for a while after seeing a comment by Charles Neil sometime back.
I just ordered some rhynosoft sanding pads & spindle sleeves. Found their prices better than others.
http://www.industrialabrasives.com/
-- Any man can be a father, but it takes someone special to be a Dad
Redoak49
#7 posted 05-15-2018 12:47 PM
No, not the ones I was referring to. Do a search for Klingspor Gold. Your link is to a lightweight disk. Cheap yes but light weight.
View jonah's profile
jonah
1976 posts in 3540 days
#8 posted 05-15-2018 01:19 PM
Check out Klingspor’s variety pack. It’s a good deal and lets you try different things to see what you like best. Then you buy more of that style.
View waho6o9's profile
waho6o9
8539 posts in 2819 days
#9 posted 05-15-2018 03:50 PM
Sampler packs on sale at Klingspors
https://www.woodworkingshop.com/itemgroups.aspx?group=may
View pintodeluxe's profile
pintodeluxe
5820 posts in 3055 days
#10 posted 05-15-2018 04:11 PM
I use Klingspor stearate paper (kind if a cream color sanding disc) the numbers will be VD9000x
Basically the 9000 series paper, and I have been very pleased with how they sand. They last a very long time as well.
