Fazlok Connectors
Forum topic by wjt99 posted 05-11-2018 11:30 PM 342 views 0 times favorited 1 reply Add to Favorites Watch
View wjt99's profile
wjt99
19 posts in 1657 days
05-11-2018 11:30 PM
I have used a couple of these for years and occasionally they have disconnected. I finally decided to do something about it.
A simple fix. With the bayonet connector fully engaged I drilled a 1/8” hole through both halves of the connection. I made a push pin from a 1/8” aluminum rivet and a mini shaker peg. Gravity and a press fit keep the pin in place but is easily removed if I need to move the hose to another port.
Bill
1 reply so far
View fivecodys's profile (online now)
fivecodys
1162 posts in 1778 days
#1 posted 05-15-2018 08:46 PM
Sounds like a good solution.
Thanks for sharing!
-- I always knew I would grow old, But I expected it to take longer!
