Cordless question:
Forum topic by poopiekat posted 747 days ago 1058 views 0 times favorited 11 replies Add to Favorites Watch
View poopiekat's profile
poopiekat
2905 posts in 1931 days
747 days ago
Topic tags/keywords: question 12 volt
I chose the DeWalt 12-volt cordless drill/driver as a Christmas present last year, with an ulterior motive. Knowing we’d be doing some rustic camping far away from a source of electrical power, I figured I could do some repairs on our travel trailer by hooking up the drill directly to either the deep-cycle battery or the truck battery. What I need to know is whether I can recharge the drill battery directly off another 12 volt source, or wire the drill directly to the camper deep-cycle battery. Please respond if you have tried this, and whether or not you got good results. As a kid, I ran my slot car track off a car battery; I’m not afraid of running small DC motors off a big power pack. I just don’t want to wreck some unknown electronic component of a nice drill. TY in advance!
11 replies so far
View brtech's profile
brtech
477 posts in 1119 days
#1 posted 747 days ago
You probably don’t want to try charging directly from the 12V unless it’s a NiCAD (not an Li Ion), and even then, you probably won’t get a full charge.
You should be able to run the tool from the camper battery however. Take the battery out, keep the polarity straight and it should work fine.
View dbray45's profile
dbray45
2007 posts in 973 days
#2 posted 747 days ago
If you have an LI battery, plug in an inverter and plug the charger into that. There is loss but the voltages will be correct. It is better to charge with the engine running and charging unless it is a different battery from the vehicle starting battery.
-- David in Damascus, MD
View David's profile
David
185 posts in 860 days
#3 posted 747 days ago
Definitely do not charge the battery pack by directly connecting it to the car battery, especially don’t if it’s a lithium drill battery. Even though the voltages may be close enough, you’ll have no control over how much current is delivered. Search for overcharging lithium battery on youtube to see why.
If you do decide to do it anyway, do it outside away from anything flammable, take a video, post it on youtube, and send me the link. It would probably be entertaining to watch.
-- Perilous to all of us are the devices of an art deeper than we ourselves possess. --Gandalf the Grey http://davidwahl.org/category/woodworking/
poopiekat
#4 posted 747 days ago
Perhaps somebody who HAS either recharged a 12V drill battery pack, or hardwired a cordless 12V drill, to a deep-cycle battery will share his/her thoughts with us.
View Gregn's profile
Gregn
1639 posts in 1180 days
#5 posted 747 days ago
The best suggestion I can make is to buy a power inverter that connects to the car battery and run your charger off of it to recharge your batteries. You can run other power tools as well depending on the rating on the inverter. Some inverters even plug in to the cigarette lighter.
Gregn
#6 posted 747 days ago
I just caught this on another forum on hard wiring to a car battery.
http://www.tractorbynet.com/forums/rural-living/30262-use-12v-car-battery-power.html
So yes you can hardwire to the battery.
View DLCW's profile
DLCW
503 posts in 851 days
#7 posted 747 days ago
I suggest an inverter plugged in to a cigarette lighter, then plug your battery charger in to the inverter. That way the drill battery is charging in its native environment.
-- Don, Diamond Lake Custom Woodworks - http://www.dlwoodworks.com - "If you make something idiot proof, all they do is make a better idiot"
poopiekat
#8 posted 747 days ago
Thanks, Gregn! I’m surprised that a tractor owner’s message board would be such a good source of info on cordless tool usage, but there it is! I’d rather not consider buying an inverter though, it just seems redundant to bump up 12 volts DC to 120 AC, and then back down to 12 volts DC again for charging; especially where using a cordless drill is about where I’d draw the line as far as truly rustic wilderness camping is concerned. Having an inverter onboard would be a great temptation to bring along the laptop, microwave, TV and DVD player and otherwise just not get the hassles of the City out of my head for a while. I just want to drill out some pop-rivets that leave a rusty streak on the surface of the camper, and replace them with aluminum ones, when I’m not busy reading, fishing or hiking. Hard-wiring it is, then! Thanks for all the great replies!
View crank49's profile
crank49
2376 posts in 1167 days
#9 posted 747 days ago
I haven’t done it, but plan to take the works out of a dead ni-cad battery pack for one of my older 12volt drills and solder a power cord into the empty battery shell with an automotive lighter type plug on the other end. I don’t stand to loose anything here since it’s an old drill for which it has become difficult to find a replacement battery. My battery has only two contact blades to connect to the drill so this is easy to figure out. I think some of the newer batteries, with more features, have more connections and might be less simple to bypass.; but I’m not positive about that.
-- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason.
View BigTiny's profile
BigTiny
1652 posts in 1085 days
#10 posted 747 days ago
Watch the Canadian Tire flyers for a sale on an inverter and use it to charge your tools, plus you can watch the game on a small TV using it too.
-- The nicer the nice, the higher the price!
View fernandoindia's profile
fernandoindia
1012 posts in 1140 days
#11 posted 746 days ago
Yes Poopie. Hardwire the drill to 12 v car batteries. I keep doing so in my sailboat since ever. Most difficult part is to make firm the wiring to the drill, in a way that when you decide to go unplugged again, everything stays in fashinable order. I do so with a 14.4v Skill drill, which I decided not to replace the batteries. So I permanently soldered the wiring with a 12v cigarrete plug. Watch the section of the wiring that needs to be big enough, and will also depend on how long is the wiring. I made mine of a 2,5 mm2 section for a 8 meter long wire. That is a 12AWG wire size for a 26’ long piece
-- Back home. Fernando
