Dewalt 7740 RAS
Forum topic by Bill J. Griffin posted 06-02-2011 10:01 AM 10586 views 0 times favorited 13 replies Add to Favorites Watch
View Bill J. Griffin's profile
Bill J. Griffin
99 posts in 2792 days
06-02-2011 10:01 AM
Topic tags/keywords: dewalt ras radial arm saw powershop 7740
I am refurbishing an old De Walt 7740 Radial arm saw, and was hoping that someone out there know something that may be of some help to me. I will try to add pics ltr. Tyvm
-- Shop's too small :( ... hey the decks pretty big :)!!!
13 replies so far
View philip marcou's profile
philip marcou
265 posts in 2838 days
#1 posted 06-02-2011 10:55 AM
Bill,
If you Google about De Walt radial saws there are many refurbishment stories there…
Let’s see a picture of yours . I have done this one here
It was basically a strip, clean, inspect and fix, spray, re-assemble. The older industrial ones are nice machines.
Bill J. Griffin
#2 posted 06-02-2011 06:01 PM
Thanks Philip.
I will be getting some pics up this weekend.
Wow, what an awesome job you did in restoring yours, it looks great.
Bill J. Griffin
#3 posted 06-04-2011 04:09 AM
Here is some pics of my DeWalt ras.
any idea if “JB weld would work to glue the two halves of the switch plate together?
View ,'s profile
2387 posts in 3788 days
#4 posted 06-04-2011 05:45 AM
Just wanted to chime in as we run a 790 and a 7730 in our small 4 man shop. They both get a lot of use. The 790 cuts our dasos and the 7730 is set up as a 90 degree crosscut saw and serves as a back up to the hitatchi sliding miter saw. We always backed up and guys would end up waiting to use the sliding mitee then the 7730 was added and now thw 7730 gets almost as much use as the sliding miter saw.
philip marcou
#5 posted 06-04-2011 05:48 AM
Bill,
I am not familiar with JB Weld, but would think that if you used an industrial epoxy combined with a backing plate of thin sheet metal it would be fine. From what I can see the upper portion looks like a housing for the switch, not as if it is under any stress..It could also be welded by someone competent with aluminium welding if you know anybody.
View bubinga's profile
bubinga
861 posts in 2908 days
#6 posted 06-04-2011 06:19 AM
Here is a link to, NBeener’s blog. Go Here, and scroll down,to the links, you will find a wealth of information
http://lumberjocks.com/NBeener/blog/21866
My blog here
Haven’t finished putting rest of , restore in, yet
-- E J ------- Always Keep a Firm Grip on Your Tool
Beginningwoodworker
13345 posts in 3914 days
#7 posted 06-04-2011 06:22 AM
Bill, thats a nice looking saw.
bubinga
#8 posted 06-04-2011 06:30 AM
Beginningwoodworker, has a cool one to !!!
Bill J. Griffin
#9 posted 06-04-2011 07:28 AM
thanks flyforfun, sounds like you have a few nice ras’s around eh?
“JB Weld” is an epoxy Philip so I think I’ll give it a try like you say with a backing of sheet metal for strength. I live in a small town and don’t know any aluminum welders unfortunately.Thanks for the feedback. EJ you and Philip have been a wealth of info for me my friends lol. Thanks for all the input.
You’ve made my job easier. :) CJ Thank you very much, I picked it up for free from a customer who was throwing it out. Took it home, plugged it in, pushed on, wshshshsh. Nice sound.:)
bubinga
#10 posted 06-04-2011 07:51 AM
There Is Allways More Than One Way To Do IT !!!
Bill J. Griffin
#11 posted 09-16-2011 09:17 PM
check out www.radialarmsawrecall.com for FREE blade gaurd and a few other goodies!!!
View emart's profile
emart
445 posts in 2869 days
#12 posted 12-22-2012 10:32 AM
I have that same model in my shop. from what i can tell mine is from about 1969-1970 the nice thing is that dewalt and black and decker STILL make and sell parts for these old machines. from what i can tell my saw had some use but most likely got put in a closet or barn for 25+ years since most of it is pristine still. I managed to score mine from the habitat for humanity store for $100 with the original stand though it needs some maintenance and a new blade. you can see some pics of it on my shop page. if you want i can scan a copy of my manual for you for more information
by the way that switch cover is probably cast aluminum which is hard as hell to weld(if not impossible) so using epoxy was definitely the best choice
-- tools are only as good as the hands that hold them https://www.custommade.com/by/emeraldcrafts/
View tbshop's profile
tbshop
18 posts in 3265 days
#13 posted 12-10-2018 04:58 PM
Hi guys, fairly new to the site although I have been stalking it for a while. I’ve recently acquired a B & D/Dewalt 7740 type 3 RAS for $50 from the Restore. Minor restoration is all it appears to need. One fault I need some help with is there is some horizontal play in the arm when locked in at a detent. I’ve tried to adjust this with the 2 left and right screws that the detent arm rides in but can’t seem to get the play out. All other functions work extremely well. I’ve considered buying two 5/8” bolts and drilling out the center and replacing the factory ones or fitting some shims on the detent shaft to take up the play. I know this site is a wealth of information, so, any thoughts? Any help would be greatly appreciated.
Tony
-- tbshop
