Jwbs-14cs stumped and calling was no help
Forum topic by Clarkswoodworking posted 05-08-2018 04:43 PM 654 views 0 times favorited 20 replies Add to Favorites Watch
View Clarkswoodworking's profile
Clarkswoodworking
288 posts in 372 days
05-08-2018 04:43 PM
Ok
I got a problem with the bandsaw
It has to do with the tracking mechanism
I took good pics
Problem is the bracket that holds the wheel shaft and adjusting is hitting the wheel spikes and for the life of me I cannot figure out why
I know it’s simple but not seeing it and calling customer service they told me that it was the upper part of the bracket has two pins and they must be broken and allowing the bracket to drop and rub
Not the case no broken parts everything is as it should be as far as I can tell but ?
Andy came by the other day and we ground a little off the bracket to make it clear but it just stated rubbing again ?
Also rubbed the inside of the case
I do not see a washer or spacer in the diagram to hold it out of the way
20 replies so far
View johnstoneb's profile
johnstoneb
3072 posts in 2411 days
#1 posted 05-08-2018 04:47 PM
Pictures of wheel would help. My guess is the bearing on the upper wheel is bad or going bad.
-- Bruce, Boise, ID
Clarkswoodworking
#2 posted 05-08-2018 04:48 PM
Nope
Bearing are like new and tighscott
Clarkswoodworking
#3 posted 05-08-2018 04:49 PM
No slop in the wheel
View TheFridge's profile
TheFridge
10817 posts in 1724 days
#4 posted 05-08-2018 05:02 PM
The arbor for the wheel looks bent. So does the bracket. Did your bearings have an extended inner race?
View Woodknack's profile
Woodknack
12465 posts in 2618 days
#5 posted 05-08-2018 05:04 PM
I hate to ask but is the hub longer on one side that would make it stick out farther? Or top and bottom wheels flip flopped?
Clarkswoodworking
#6 posted 05-08-2018 05:08 PM
It is all original parts
Cannot bend bracket it is casted aluminum it would have broken
Nothing bent ?
It’s just not right ?
Scott
Clarkswoodworking
#7 posted 05-08-2018 05:09 PM
Van somebody take a couple pics of theirs ?
Please
Thanks
Scott
TheFridge
#8 posted 05-08-2018 05:38 PM
Cast aluminum can bend. Once.
That arbor and bracket are supposed to be at 90deg.
Clarkswoodworking
#9 posted 05-08-2018 05:54 PM
Oh
Ok I didn’t know that
Well maybe that dang bracket is bent !
Lovely as they do not sell that part
Scott
Clarkswoodworking
#10 posted 05-08-2018 05:56 PM
At least it is not going to keep me from my work until it’s figured out
I have another very nice saw to use
Scott
Clarkswoodworking
#11 posted 05-08-2018 07:41 PM
Ok ok
Dang it again!
I disassembled the unit to find that the bracket being bent will not allow me to remove it *%¥|£<•\%|%^|¥\¥\
Scott
TheFridge
#12 posted 05-08-2018 07:56 PM
You should be able to pull the screws out that hold the cover and blade guard. After that it should slide up and out easily.
I know about bending mainly because of an OWWM rule that goes something like this: zinc, cast aluminum, pot metal, zamack will bend once. After that. It will break.
I discovered this rule a little too late :)
Most of the 14” saws are clones anyway. There’s gotta be something out there that will work.
Clarkswoodworking
#13 posted 05-08-2018 08:04 PM
Got it out
Yep she is cracked
Now another question?
Can I heat it up and try and get it back?
Thanks
Scott
View MrUnix's profile
MrUnix
7106 posts in 2437 days
#14 posted 05-08-2018 08:25 PM
- Clarkswoodworking
No. It needs to be replaced.
Clarkswoodworking
#15 posted 05-08-2018 08:32 PM
Now where to get one ?
Scort
