Curved T-track
Forum topic by richgreer posted 05-31-2011 10:39 PM 5704 views 0 times favorited 15 replies Add to Favorites Watch
View richgreer's profile
richgreer
4541 posts in 3189 days
05-31-2011 10:39 PM
I don’t even know if curved t-track exists.
Does anyone know of a source for buying a curved t-track and/or does anyone have experience trying to curve a straight piece of t-track?
In theory, I might be able to make a functional curved t-track if I cut into the aluminum from one side about 3/4 of the way across the track and make a cut every half inch or so.
Ideally, I would like a half circle of t-track with a 3 – 4” radius.
15 replies so far
View live4ever's profile
live4ever
983 posts in 3124 days
#1 posted 05-31-2011 10:52 PM
I don’t have any helpful info, but which way are you wanting to curve it?
View Kris Koenig's profile
Kris Koenig
11 posts in 2971 days
#2 posted 05-31-2011 11:02 PM
Does it have to be aluminum? Or could you use a t-slot router bit and a circle jig to cut one in wood?
View mnguy's profile
mnguy
193 posts in 3512 days
#3 posted 05-31-2011 11:04 PM
Rich:
Why not use a T-track router bit (Lee Valley carries one http://www.leevalley.com/US/wood/page.aspx?p=51233&cat=1,46168,46176&ap=1) and make the track out of either hard maple or plastic? Even if you can kerf bend some aluminum t-track, I suspect you’ll wreck enough to more than pay for this bit.
View saddletramp's profile
saddletramp
1180 posts in 2752 days
#4 posted 05-31-2011 11:43 PM
Okay, I just got to ask, Why do you want to curve it?
-- ♫♪♪♫♫ Saddletramp, saddletramp, I'm as free as the breeze and I ride where I please, saddletramp ♪♪♪♫♪ ...... Bob W....NW Michigan (Traverse City area)
richgreer
#5 posted 06-01-2011 12:15 AM
My desire for a curved t-track is due to my desire for an tilt adjusting mechanism for a music stand that really works well.
However, the idea of using a router bit to make a t-track in wood is something I had not thought of. I’ve thought of a dozen or more different ways to make the tilt adjustment and all of them seemed iffy.
FYI – I planned to use a t-track in the column for height adjustment. In theory, that could be done with a router also.
Thanks for the feedback.
I’ve got to give Deke credit for one of the more creative ideas I have heard.
View rhett's profile
rhett
742 posts in 3781 days
#6 posted 06-01-2011 12:25 AM
I think you could bend it yourself. Like bending any metal with a preformed shape, the trick would be to put material in the negative space to keep it from deforming. Maybe some strips of mdf?
The router bit sounds promissing but only if its cut into some sort of engineered substrate. I could see solid wood giving you some issues down the road.
Good Luck
-- Doubt kills more dreams than failure.
View Viktor's profile
Viktor
466 posts in 3533 days
#7 posted 06-01-2011 02:00 AM
There is a Scketchup plugin called shapebender.
http://lumberjocks.com/topics/24206
You can draw a t-track and bend it. This works great if you live in the Matrix. Not sure it will work in the physical world.
View woodman71's profile
woodman71
162 posts in 3438 days
#8 posted 06-01-2011 02:27 AM
Well Rich you could bend it if you have a preformed shape . The trick to do this is with heat like propane torch be careful not to get metal to hot but hot enough to bend it also if your radius is to tight it might not work
View Loren's profile
10477 posts in 3762 days
#9 posted 06-01-2011 02:56 AM
You can get curved 80-20 extrusion I think. It’s used for corners on
conveyer assemblies and stuff like that.
View Bernie's profile
Bernie
422 posts in 2951 days
#10 posted 06-01-2011 04:36 AM
Yes Rich… I was going to suggest a wood track. Don’t think they sell them on the market because there are too many radius possibilities.
Pipe fitters have bending tools for pipes.
You could also by a cabinet lid stay with a curved guide. Use the stainless steel slotted guide.
Last option… go with Deke’s idea. I like it!
-- Bernie: It never gets hot or cold in New Hampshire, just seasonal!
View Dark_Lightning's profile
Dark_Lightning
3215 posts in 3223 days
#11 posted 06-01-2011 04:56 AM
You could also contact a local machinist and have him make you one on his milling machine in trade.
-- Random Orbital Nailer
View CADguy's profile
CADguy
5 posts in 2714 days
#12 posted 06-01-2011 05:06 AM
I suggest using something like a 1/2” or 3/4” straight bit in a piece of stock then glue on a 1/8” thick piece of oak plywood and then(after the glue has dried) use an 1/8” straight bit following the same pattern to make a slot. All my sleds are set up this way for stops, etc. It works great and the plumbers bolt fits in the slot perfect and slides well too. I’ve never done a curved one but as long as you set it up good and pay attention to what you’re doing it should work.
-- "Country Roads, take me home to the place I belong...West Virginia..."
View Grandpa's profile
Grandpa
3261 posts in 2789 days
#13 posted 06-01-2011 05:41 AM
Make it from wood and laminate it. Start with a base and curve it then add parts and glue them in place and add pieces daily until it has the shape you need. It should stay curved just like you built it.
117203 posts in 3691 days
#14 posted 06-01-2011 06:35 AM
Here’s some
View timster's profile
timster
2 posts in 2144 days
#15 posted 11-04-2012 06:49 AM
http://www.medicalproductsdirect.com/hanprivscree2.html
hospital curtains use a curved T-track made of aluminum.
