Can you use a miter saw to cut
Forum topic by Clarkswoodworking posted 05-08-2018 02:45 PM 542 views 0 times favorited 18 replies Add to Favorites Watch
View Clarkswoodworking's profile
Clarkswoodworking
125 posts in 127 days
05-08-2018 02:45 PM
Hcan you make dados with a compound miter saw ?
Thanks
Scott
18 replies so far
View ShaneA's profile
ShaneA
6928 posts in 2592 days
#1 posted 05-08-2018 02:52 PM
A sliding saw will give you limited dado capacity, assuming it has a depth stop. My Makita does. Not ideal, but in a pinch…it can be done.
Clarkswoodworking
#2 posted 05-08-2018 03:00 PM
I’m running out of room
Already have more toys then the space to put them
It’s either a tablesaw or compound saw
Thanks
Scott
View John Smith's profile
John Smith
862 posts in 156 days
#3 posted 05-08-2018 03:04 PM
Table saw ~ with an assortment of sleds.
plus – I think it will be less hassle changing blades on a T/S vs the Miter.
-- Graduated Valedictorian from the University of HardKnocks --
ShaneA
#4 posted 05-08-2018 03:06 PM
The table saw, and its vast array of jigs and accessories make it infinity more versatile and useful than any compound miter saw IMO.
View rwe2156's profile
rwe2156
2916 posts in 1474 days
#5 posted 05-08-2018 06:05 PM
Rule #2b of ww’ing: you MUST have a table saw.
Rick Dennington
5851 posts in 3188 days
#6 posted 05-08-2018 07:37 PM
Table saw by all means…..and a good set of dado blades….You’ll be in business then….!!
View NeophyteGrant's profile
NeophyteGrant
61 posts in 502 days
#7 posted 05-08-2018 08:07 PM
Tablesaw is far more useful. The only reason I use a CMS is to cutoff dimensional lumber that would be too big for a tablesaw. CMSs are more useful in carpentry and they’re also tougher to get an accurate cross-cut with. They’re a good roughing tool—hence the carpentry angle.
And I think that it would be a bad idea safety wise, quality wise and relatively difficult to attempt to do a dado fully with a CMS (you could kerf the edges and remove waste with a chisel much easier than removing all the waste with a CMS—would someone do it entirely with a CMS? Just seems like a bad idea). Either freehand routing, router table, or dado stack would be better to create a dado. I don’t use a dado stack but I don’t think they can do stopped dados with a circular blade?
-- Bucktown, Chicago, IL
View Woodknack's profile
Woodknack
11601 posts in 2373 days
#8 posted 05-08-2018 08:09 PM
A router is fantastic for dadoes, rabbets, and grooves.
View MrRon's profile
MrRon
4758 posts in 3237 days
#9 posted 05-09-2018 01:20 AM
Most miter saws I’ve seen, don’t have an arbor long enough for a dado stack.
View bondogaposis's profile
bondogaposis
4717 posts in 2344 days
#10 posted 05-09-2018 02:49 AM
Anybody that owns a table saw would never be tempted to try a dado with a miter saw. I’m not sure you could even do it, but it would be a lot more limited if you could. If I had a choice to give up my table saw or miter saw. The miter saw would go, it is far less versatile.
-- Bondo Gaposis
Clarkswoodworking
#11 posted 05-09-2018 02:59 AM
Ok
I got the answer I was looking for
Love you guys
I can save time and a headache (though I have never had a headache)
Scott
View cabmaker's profile
cabmaker
1730 posts in 2802 days
#12 posted 05-09-2018 12:18 PM
Tablesaw is far more useful. The only reason I use a CMS is to cutoff dimensional lumber that would be too big for a tablesaw. CMSs are more useful in carpentry and they re also tougher to get an accurate cross-cut with. They re a good roughing tool—hence the carpentry angle.
And I think that it would be a bad idea safety wise, quality wise and relatively difficult to attempt to do a dado fully with a CMS (you could kerf the edges and remove waste with a chisel much easier than removing all the waste with a CMS—would someone do it entirely with a CMS? Just seems like a bad idea). Either freehand routing, router table, or dado stack would be better to create a dado. I don t use a dado stack but I don t think they can do stopped dados with a circular blade?
Ive been getting accurate cuts with a compound mitre saw for 40 plus years,,,,,dang it,,,,,why didn’t anyone tell me you couldn’t do that !
- NeophyteGrant
View AlaskaGuy's profile
AlaskaGuy
4119 posts in 2302 days
#13 posted 05-09-2018 02:59 PM
Ive been getting accurate cuts with a compound mitre saw for 40 plus years,,,,,dang it,,,,,why didn t anyone tell me you couldn t do that !
- NeophyteGrant
- cabmaker
I’d still rather use a table saw for dadoes.
View oldnovice's profile
oldnovice
6826 posts in 3361 days
#14 posted 05-09-2018 07:30 PM
How about a router instead of a TS, not a miter saw.
I have seen videos of ”Norm” using his radial arm saw!
View Mike_in_STL's profile
Mike_in_STL
638 posts in 527 days
#15 posted 05-09-2018 07:52 PM
I’ve used my RAS for dadoes. One pass of the blade at a time. It works but I should get a dado stack.
Router is faster, wider bit, and my TS is only good for ripping. It’s a portable plastic and aluminum $100 thing. I’ve out grown it.
I’d be wary of using the miter saw. I can’t see how you’d have much capacity and the chance of sawing through it high.
-- Sawdust makes me whole --Mike in STL
