Boice Crane Spindle Sander
Forum topic by SnowyRiver posted 05-30-2011 02:15 AM 7027 views 0 times favorited 3 replies Add to Favorites Watch
View SnowyRiver's profile
SnowyRiver
51457 posts in 3390 days
05-30-2011 02:15 AM
I have the opportunity to buy a Boice Crane oscillating spindle sander for $475. The spindle bearings have been changed. It also comes with quite a variety of spindles and sanding sleeves. The machine is supposed to be in top running order although I understand it was manufactured in the 1970s. What do you think? Is it worth the price? I havent had any Boice Crane equipment before, but it looks nice in the pictures.
Thanks
-- Wayne - Plymouth MN
3 replies so far
View Jack Barnhill's profile
Jack Barnhill
366 posts in 3275 days
#1 posted 05-30-2011 02:24 AM
Just a quick check at Jet and Grizzly show that they have functional equivalents and $1150 and $665 respectively. At $475 and in top working order, MHO would be that it seems to be a reasonable price.
My only concern, for myself, would be that I don’t have any experience in rebuilding these units so if something would happen to break on it, would I be able to fix it.
-- Best regards, Jack -- I may not be good, but I'm slow -- www.BarnhillWoodworks.com
View JPierce's profile
JPierce
8 posts in 2514 days
#2 posted 05-30-2011 02:24 AM
Just an off hand guess, but I would think it is worth it. At one time I had an old Boice Crane table saw and it was well built with nice fit and finish on everything. A good quality machine.
I personally would prefer that sander used,instead of a lower quality new one.
View dblphotography's profile
dblphotography
1 post in 2471 days
#3 posted 05-30-2011 03:13 AM
I have a Boice Crane 26” scroll saw that was manufactured in the late 50’s / early 60’s and from what I can tell. The top had a bit of rust, which was easy to clean up. I changed the belt and it runs great with 60 minutes of prep. These are industrial machines and agree that it would be a better purchase than the newer ones at a much higher price. Mine had a quality Dayton motor. Plan to do a full restoration at some point, but it works fine now, so it will get some use before restoration.
Check out the Old Woodworking Machine Sites on Boice Crane.
http://vintagemachinery.org/mfgindex/detail.aspx?id=111 – Company Info
http://vintagemachinery.org/pubs/detail.aspx?id=645 – A Spindle Sander Manual
