Drawer Slide
Forum topic by Kevin posted 05-29-2011 05:32 AM 1091 views 0 times favorited 4 replies Add to Favorites Watch
View Kevin's profile
Kevin
462 posts in 3111 days
05-29-2011 05:32 AM
Topic tags/keywords: slide drawer
Just a quick question here. I thought if the opening was 22” then you would need to cut the width at 21.5”
Here is the link for the ones I bought at lowes. I tested 21.5”, but with the slides attatched it appears that it may need a 1/2” on each side instead.
So my question is what’s the inches that needs to be subtracted for the slides usually.
Link:
http://www.lowes.com/pd_89226-89973-P1700/12-W_0__?productId=3060897&Ntt=drawer+slides&pl=1&currentURL=%2Fpl__0__s%3FNtt%3Ddrawer%2Bslides&facetInfo=
-- Williamsburg, KY
View HerbC's profile
HerbC
1721 posts in 2766 days
#1 posted 05-29-2011 05:43 AM
From what I’ve read, 1” is USUALLY a good figure but the bottom line is get your slides and size your drawers to work with the slides…
Good Luck!
Be Careful!
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
Kevin
#2 posted 05-29-2011 06:04 AM
Thanks Herb,
It is exactly 1” that is needed.
I’m taking my scrap cherry and walnut wood that doesn’t have the best pattern and making drawers for base cabinets for my garage :)
Kevin
-- Williamsburg, KY
View Jahness's profile
Jahness
70 posts in 2670 days
#3 posted 05-29-2011 07:04 AM
Actually, 1 1/32” works the best.
-- John
View hooky's profile
hooky
365 posts in 3225 days
#4 posted 05-29-2011 01:20 PM
every body has the answer right
1 inch is the standard
you want the difference between carcass and draw to be no smaller than 1 inch but as jahness says you can go as wide as 1 1/32 because the left side is slightly open
the most important part is to make sure your runners in the carcass are parallel
Hooky
-- Happiness is a way of travel , not a destination (Roy Goodman)
