Plea for help - mortise in 4x4
« back to Joinery forum
Forum topic by rmh09 posted 05-01-2018 07:39 PM 2127 views 0 times favorited 32 replies Add to Favorites Watch
View rmh09's profile
rmh09
22 posts in 2927 days
05-01-2018 07:39 PM
Topic tags/keywords: workbench joinery mortise
I am attempting to build a fairly basic work bench. The top is glu-lam 5 1/4” thick x 6.5’ long by 22” wide (heavy). For the base I wanted to try thru tenons using 4×4’s. This is a long sad tale full of opportunity to learn from many iterations. I will spare you most of them. I first used a drill press with a 1/2” auger bit to hog out the mortise. There was too much clean up left and the moritise looked unusable unless I wanted to spend hours cleaning it up with chisels. I then went to two holes with the bit and then used a jig saw. Again, not usuable. Then, I went to two holes, jig saw out the waste and THEN use a long straight router bit = 2 1/2”, (flipping the leg to get the 3 1/2” depth). I made a jig for the router using a bushing to keep it within bounds. Nothing seems to get me to a decent mortise. Even after using an ocsillating spindle sander to smooth out the sides, the mortise is down right ugly! I could attach the legs and stretchers with metal brackets but I want to try to figure out if a good square mortise (maybe with rounded corners) is possible. Any help would greatly be appreciated. Thanks!!
-- Randy
32 replies so far
View CRAIGCLICK's profile
CRAIGCLICK
117 posts in 311 days
#1 posted 05-01-2018 07:54 PM
I, too suck at mortises..but practice helps a lot. Using scrap soft pine and then moving your way up to harder woods, spend a lot of time on your chisel work and it will pay off.
Use a good straight piece of wood as a guide (place it at the edge of the mortise once you drill it out and use it as a guide for your chisel when paring down the sides and corners….that helped me a lot.
Your other alternative is to find a used mortising machine. I purchased one (a Jet JBM-5) from a fellow Lumberjocks member for 150 bucks and it is TOTALLY worth the money in time saved.
Of course, given the time, I’d rather do them by hand…it helps me “connect” to the project…but when you need to do something right now, the mortising machine certainly is a godsend.
-- Somewhere between raising hell and amazing grace.
View AlaskaGuy's profile
AlaskaGuy
4990 posts in 2547 days
#2 posted 05-01-2018 09:14 PM
Do you have a band saw? Cut a saddle in the post and glue a block in place.
rmh09
#3 posted 05-01-2018 09:36 PM
Thanks AlaskaGuy! I may have to do it your way. The 4×4 is just too thick at 3 1/2” for to get straight sides any other way.
-- Randy
AlaskaGuy
#4 posted 05-01-2018 10:03 PM
- rmh09
I guess you know the first thing you should do is make sure all 4 of your post/leg are square. Start at the jointer and square them up. It will save you grief later when you assemble everything.
View TheFridge's profile
TheFridge
10816 posts in 1724 days
#5 posted 05-01-2018 10:27 PM
It won’t take hours to clean it out with chisels. Unless you have a mortiser or use a router you’ll have to clean it out by hand anyway. The inside of the mortise may be serviceable off the bandsaw but you’ll still need to clean it out with chisels.
View Rayne's profile
Rayne
1123 posts in 1777 days
#6 posted 05-01-2018 11:05 PM
- rmh09
Another way is to take 2 – 2×4’s and cut the appropriate dado’s in each side and glue it together as one.
AlaskaGuy
#7 posted 05-01-2018 11:11 PM
- rmh09
Another way is to take 2 – 2×4 s and cut the appropriate dado s in each side and glue it together as one.
- Rayne
You can also build up the leg using 3 pieces of wood, omitting the area were you want the mortise.
View BFamous's profile
BFamous
226 posts in 358 days
#8 posted 05-02-2018 01:05 AM
One thing to note, the inside of your mortises don’t need to be pretty…
Personally, I prefer to use a good sharp chisel after hogging out the meat. If the chisel isn’t razor sharp, you’ll be crushing g the wood fibers instead of cutting them. I like to use a chisel the width of the narrowest side of my mortise, it means I can clean up at least two of the sides of the mortise in one pass from each side of the board. The only thing you need to be certain of is that you mortise sides are square to each other and either square or parallel to the side of the board – you don’t want your mortises to be crooked. And that’s easy enough to do using a marking gauge, but you want to ensure you’re right on those marks
Also remember, practice makes (closer to) perfect.
-- Brian Famous :: Charlotte, NC :: http://www.FamousArtisan.com
rmh09
#9 posted 05-02-2018 02:06 AM
This is some very good advice. I don’t think I would have as much of a problem with the mortise if it was normal sized (1 or 1 1/2” thick). This is HD pine 4×4, the mortise measures 2” x3”. Soft wood that “should” be easy to tame, just not by me. Every one that have attempted has been very wonky. Not straight, wavy, and rough on the inside. I will try another method. I really appreciate your help!
-- Randy
TheFridge
#10 posted 05-02-2018 02:09 AM
I use a 2”x2”x2” square of ebony to register my chisels at 90deg. Not so much anymore but this method worked on my 2-3/4” benchtop.
View Holbs's profile
Holbs
2032 posts in 2267 days
#11 posted 05-02-2018 04:16 AM
why not go bridal joint? I am currently slogging through 4”x6” for legs & stretchers for my joinery bench.
View MrWolfe's profile (online now)
MrWolfe
100 posts in 361 days
#12 posted 05-02-2018 04:25 AM
Rayne’s suggestion works well. You can cut the waste out of each half of the mortise on a table saw with a dado set if you have one. Its easy enough to clamp or tape the two halves of the leg together side by side and run them through your saw on a sacrificial fence attached to your miter gauge. This will make the dados on the two halves exactly the same dimension. Make a plug out of scrap 2×4 that is the size of the tenon and wrap it with packaging tape. You can then glue the two halves of the leg together around the plug/tenon and get really tight alignment. The packaging tape will not stick to the glue and you can knock the plug out with a mallet after the glue sets.
Hope that helps.
A good set of mortise chisels would be great too.
View jimintx's profile
jimintx
864 posts in 1822 days
#13 posted 05-02-2018 05:12 AM
This video from Paul Sellers helped me understand the best use of chisels for making a mortise. I recommend it.
https://www.youtube.com/watch?v=q_NXq7_TILA
-- Jim, Houston, TX
View MikeB_UK's profile
MikeB_UK
151 posts in 1272 days
#14 posted 05-02-2018 08:32 AM
I did my first mortises on for my bench as well.
Clean up with chisels seems like it will take an age but gets faster as you get the hang of it..
First one took about 3 hours
Last one took 20 Minutes
Clean up half from one side and half from the other, so you only need to get 1 3/4” square at any one time.
-- If I say I'll fix something around the house I will, there is no use nagging about it every 6 months.
View chrisirving's profile
chrisirving
122 posts in 669 days
#15 posted 05-02-2018 12:08 PM
I did Maloof joints because I wanted the legs to be flush with the sides for a leg vise…and they look good ;). They were fairly easy to cut and fit
showing 1 through 15 of 32 replies
