Quick Tip...Easy Access to Drill Accessories
Forum topic by bubinga posted 05-28-2011 03:28 AM 1628 views 0 times favorited 1 reply Add to Favorites Watch
View bubinga's profile
bubinga
861 posts in 2787 days
05-28-2011 03:28 AM
Topic tags/keywords: tip drill press drill-driver peg board
Here’s a quick and easy way to keep drill press accessories close at hand when you’re working in the shop. A common pegboard has just the right size holes for inserting the 1/4” shank of most wheels and brushes. For accessories with a larger shank, simply enlarge the hole slightly with a drill.
-- E J ------- Always Keep a Firm Grip on Your Tool
1 reply so far
View CADguy's profile
CADguy
5 posts in 2719 days
#1 posted 05-28-2011 11:34 AM
Not a bad idea at all. I took a 2×4 about 5 ft long and drilled the face of it at about a 25 degree angle, 3 wide in 1” increments with a 3/8” bit for the length of it and mounted it vertically on the wall beside/behind my press. The 25 degree angle slopes towards the ceiling. I have about 80 spots to stick stuff on there. 2×4 was all I had handy at the time or I might have done it different. It works though. I’d have probably used pegboard if I had it. Haha
-- "Country Roads, take me home to the place I belong...West Virginia..."
