Earlex 5500 for painting patio furniture
Forum topic by moke posted 05-01-2018 03:02 AM 1459 views 0 times favorited 16 replies Add to Favorites Watch
View moke's profile
moke
1229 posts in 2896 days
05-01-2018 03:02 AM
I have had very good success in spraying different types of poly, and my wife thinks I need to repaint our patio furniture ( several sets ). It is aluminum, so I would sand and spray with aluminum primer. Is my Earlex 5500 good enough to give me a decent finish with, what I would assume would be some sort of automotive paint.
Or…do I need to buy an Earlex 6003? Hint…hint…..LOL. I guess I wouldrather not if I didn’t have to…...but replacement furniture would be thousands, so if that is what I need to do, it would be ok.
So, my question is two-fold:
Is the one stage HVLP going to be sufficient?
What sort of paint should I use?
Thanks in advance….we have some of the best DIYers around…...I thought I would check with you, even though this is not about wood…..
-- Mike
16 replies so far
View therealSteveN's profile
therealSteveN
1226 posts in 694 days
#1 posted 05-01-2018 05:48 AM
I only spray in temps above 65, and I spray indoors most of the time. I have gone to all General Finishes for any of my top coats. For a nice sprayed on clear-coat I like GF High Performance water based top coat I’ve had good luck with it, in my Earlex 5500.
Here is a short video of the 2, strain impurities
It is about finishing wood, for me it’s all same same.
For paints there are a bunch of videos from Earlex about using the 5500, several are about different aspects of paint. The key there is using that straining cup, to get the paint thinned down so the drops drip at the rate suggested. Here is where to start looking
Good luck, and as with any finishing always do tests first on the same species of wood, prepped to the same level as your project. Much better to mess up on a scrap, than something you’ve spent 100 hours making.
-- Think safe, be safe
View John Smith's profile (online now)
John Smith
1312 posts in 282 days
#2 posted 05-01-2018 12:01 PM
Mike – after all the cleaning and prepping, spray it all down with regular white vinegar
(and rinse well) prior to the primer – this is to etch any bare metal for good adhesion.
and also help to neutralize any oxidation or corrosion that may be present.
-- some people are like a Slinky - - - pretty much good for nothing. But still make you smile when you push them down a flight of stairs.
View moke's profile
moke
#3 posted 05-01-2018 04:39 PM
Thanks guys—-
John, if vinegar etches the metal, it won’t hurt my gun will it?
-- Mike
View Earlextech's profile
Earlextech
1162 posts in 2810 days
#4 posted 05-01-2018 06:03 PM
You should definitely upgrade to the HV6003PUS! But if you don’t the 5500 will work just fine. If you’re going with an enamel paint I would use the 1.5mm needle set and most likely thin the paint 5-10%. Also, vinegar won’t do your gun any favors, a plastic spritz bottle would be better.
View moke's profile
moke
#5 posted 05-01-2018 09:38 PM
Sam, I was hoping you would chime in….I used “Earlex” in the subject line for that purpose…..and I am pretty sure that I should buy a 6003 too, but I was bad last year…real bad….so I need to lay a little low for a year or so.
So I should get some enamel? We have a very reliable Sherwin Williams next to my favorite tool store…..
Thank you
-- Mike
John Smith
#6 posted 05-01-2018 10:46 PM
Mike – the vinegar run through your sprayer just might clean it out a little, like a coffee maker.
but I was referring to the hand held spray bottle or if you have many big pieces, the 1gal. garden sprayer.
View Rich's profile (online now)
Rich
3545 posts in 709 days
#7 posted 05-01-2018 10:47 PM
- John Smith
Looks blue to me.
woodbutcherbynight
5545 posts in 2528 days
#8 posted 05-02-2018 01:47 AM
- John Smith
Looks blue to me.
- Rich
It has blueberry scent added.
LOL
Rich
#9 posted 05-02-2018 04:36 AM
Looks blue to me.
- Rich
LOL
- woodbutcherbynight
Yeah, but are they blueberries, or blue berries? (Gotta be a Taxi fan to get that one)
View Ken90712's profile
Ken90712
17570 posts in 3308 days
#10 posted 05-02-2018 01:47 PM
Great info Thx for sharing.
View moke's profile
moke
#11 posted 05-04-2018 05:26 PM
So I should use an enamel? An automotive enamel? Recommendations? It will be out doors so I want to avoid fading….
woodbutcher: I hate blueberries, can I get another scent? Like maybe “Grilling Beef”? LOL
-- Mike
Rich
#12 posted 05-04-2018 05:59 PM
Mike, I can say that we’ve been using Rust-Oleum enamel on the wrought iron around the pool and gate across the driveway. It’s been two years since we first started painting and it’s showing no signs of failure.
They do make an aluminum primer that they claim eliminates blistering and peeling. They recommend it be topped with their professional enamel. I have not used the aluminum primer however, so I can’t say for sure how it performs.
Here’s the link to the primer page. https://www.rustoleum.com/product-catalog/consumer-brands/professional/aluminum-primer
John Smith
#13 posted 05-04-2018 07:19 PM
if anyone wants to visit an aluminum boat forum just for grins,
and maybe gain some information, drop by The Tin Boat Forum
where cleaning, prepping, priming and painting aluminum is a daily hot topic
just as woodworking and finishing is here on this forum.
also the ongoing battle with oxidation and corrosion.
this is an article I wrote some time back: All About Primers
I personally am a Rust-Oleum fan. I use their latex aluminum primer and Topside enamels.
I have refurbished half a dozen Tin Boats over the past few years and this is my #1 choice.
if it is good enough for an aluminum boat around salt water, it should be okay in your back yard.
the wooden seats are white oak primed and painted with Rust-Oleum enamel.
View moke's profile
moke
#14 posted 05-07-2018 08:00 PM
John, While that sounds absolutely perfect, it will need to be a custom mix and in satin…...any ideas for that?
-- Mike
John Smith
#15 posted 05-07-2018 08:08 PM
nope – no ideas.
when I need a custom mix and sheen, I go to my local paint store and they mix it for me.
I am just covering the bases for your prepping and priming.
you and the Missus will have to take it from there.
there is just too much involved to start a tutorial on messing around with gloss modifying
additives to alter the sheen.
good luck in your project – some before and after photos would be nice. (even tho it’s not a wood project).
