indexing on a lathe / looking for a chuck for the Jet 1014VSI
Forum topic by gurnie posted 726 days ago 492 views 0 times favorited 1 reply Add to Favorites Watch
View gurnie's profile
gurnie
341 posts in 1205 days
726 days ago
Ok i am close to imagining how this is done but the light bulb is still flickering. I understand you can use the pins in the indexing holes and the piece will stay in place and not turn… but then how do people remove wood in order to flute a column? do i use a my mini router and remove wood? what surface do i rest my router on, the tool rest? I know part of the reason i can’t imagine this is because my lathe hasn’t arrive in the mail.
also probably a silly question but the Jet 1014VSI does NOT come with a chuck correct? anyone want to throw their suggestion out for a good chuck for this lathe? right now i just want to turn mini birdhouses (christmas decorations) and i really haven’t figured out what else i’d be interested in turning. Something low priced but not so low price that the wood is going to fly out and clock me in the forehead
Thanks!!
Gurnie
-- Please visit my Etsy site, http://www.etsy.com/shop/cgurnham or http://www.christinagurnham.com You can also follow me on my artfire blog: http://www.artfire.com/users/cgurnham/blog
1 reply so far
View 000's profile
000
3352 posts in 786 days
#1 posted 726 days ago
you mark it out in pencil then take the first pass with a hand saw rotating the lathe by hand and then take chisels to it to finish it.
There’s specialty machines for turning things like that but you don’t need one to make a few table legs just practice a bit and you’ll suss it out lickedy split. .
Hint: The way to get the hand saw to cut the exact depth you want is to clamp two little strips of on either side of the blade back from the teeth the depth you want. A gent’s DT saw is ideal because the blade is narrow. That saw cut is your depth gauge as you chisel. You only want to remove it not deepen the cut appreciably.
-- When the moderator chooses sides, his site sucks.
