Kreg Shelf pin jig question
Forum topic by woodworkingdrew posted 04-27-2018 04:57 AM 334 views 0 times favorited 3 replies Add to Favorites Watch
View woodworkingdrew's profile
woodworkingdrew
190 posts in 1728 days
04-27-2018 04:57 AM
Planning to start construction on a shoe rack for our closet. Do most of you drill the holes first in the wood or finish the piece first than drill the holes. I am worried if I drill the holes first, I will get polyurethane in them and need to re-drill them. I however don’t want to mess up the finish with the jig. Thanks
-- Andrew, California
3 replies so far
View BFamous's profile
BFamous
158 posts in 239 days
#1 posted 04-27-2018 10:58 AM
I always drill my holes first because I do them on a drill dress before I assemble the piece. I’m not certain how you would drill the holes for the pins in the back of the shoe rack if you did it after assembly – that seems like it could involve some awkward contortionist work.
I then take the time to plug the holes with something I can pull out after applying the paint/stain/finish (typically just spare dowel pieces I have laying around the shop). Of course, make certain to take them out before the finish dries or they could get stuck.
-- Brian Famous :: Charlotte, NC :: http://www.FamousArtisan.com
View LesB's profile
LesB
1801 posts in 3562 days
#2 posted 04-27-2018 08:17 PM
I always try to do all that sort of work before I assemble because it is so much easier….including finish sanding.
Even if you have to clean up the holes after it will be easier than drilling them after assembly.
-- Les B, Oregon
View Bill White's profile
Bill White
5050 posts in 4079 days
#3 posted 04-27-2018 08:41 PM
I made my jig from peg board, and use a VIX bit to drill the holes. Drill first, then finish.
-- bill@magraphics.us
