| Forum topic by richgreer | posted 729 days ago | 1161 views | 0 times favorited | 14 replies | ![]() |
729 days ago |
I’m a fan of those basic wooden screw clamps. Everyone probably knows that you can pick one up with both handles and spin the jaws around to make them compress or expand. I do not have the ability to look at a clamp and no instinctively which way to spin the jaws to make them expand or contract. I always try it one way, see if the jaws are moving in the desired direction and, if not, reverse the direction of the spin. Does anyone have the knowledge to instinctively know which way to spin the jaws? -- Rich, Cedar Rapids, IA - I'm a woodworker. I don't create beauty, I reveal it. |
14 replies so far
#1 posted 729 days ago |
I’m proud of you for admitting this! I love them too and yes, I have to check every time! I suppose you could mark one side; that way you’d know that when the marked side is facing you, you spin xxxx direction. :) -- My dad and I built a 65 chev pick up.I killed trannys in that thing for some reason-Hog |
#2 posted 729 days ago |
Put a round arrow on the end of the handle. Would that work? I have the screws to make two, I just haven’t gotten around to it. -- Although the voices aren't real they have some pretty good ideas. |
#3 posted 729 days ago |
That is a very simple, yet incredibly good idea. Why didn’t I think of that? Thank you. As an FYI, one of the great things about these clamps is that you can buy the hardware and custom design your own jaws for any special application you happen on to. I’ve done that a couple of times. -- Rich, Cedar Rapids, IA - I'm a woodworker. I don't create beauty, I reveal it. |
#4 posted 729 days ago |
I instinctivly pick them up with the lower handle in my right,(open jaws facing up) then righty tighty, and lefty lucy. But Ive been using them for a long time, the proper name is handscrew. Good luck with it |
#5 posted 729 days ago |
Like Cabmaker said, I always pick them up the same way. If I hold a clamp with the screw closest to the end in my left hand, then spinning the clamp so that my left hand (yes, I’m left handed :) ) goes away from me when it’s at the top of its circle and toward me at the bottom, then the clamp is expanding. I think as long as you pick some trick like that, whatever it is that works for you, you’ll get the hang of it quickly. I wanted to like these clamps for a long time. They’ve been around forever, so there must be something good about them. After I figured out how to open/close them easily, I really like them, and bought more of them in different sizes. |
#6 posted 729 days ago |
What I like about them is you are able to focus an incredible amount of force with minimum smite on your work |
#7 posted 729 days ago |
Rich – I’m also proud of you for admitting this and also for admitting the fact you listen to NPR in a different post. I also like NPR. But to the question at hand. I have and like hand screws and like lots of you, I also have a hard time orienting my turning direction. I do know that to properly use them, you need to adjust the inside screw to the thickness of the wood you’re trying to squeeze and just snug it tight. Then you raise the back screw open in order ti squeeze the nose of the clamp. As it pivots on the inside screw, you may have to adjust it. To put it into perspective, snug up the jaws level and squeeze it tight with the back screw. -- Bernie: It never gets hot or cold in New Hampshire, just seasonal! |
#8 posted 729 days ago |
When teaching my Fundamentals class, I love telling them about clamps. The truth is, I’ve hated handscrews from the time I first saw them in my Jr. High woodshop class until about 2 years ago. All because I never knew which way to consistently turn them to tighten them. Then a fellow instructor told me the trick: Pick them up with the rear handle in your right hand, then the ole “Righty-Tighty, Lefty Loosey” works like a charm, EVERY TIME. With that, I’ll tell you I’m still not in love with them but I do find uses for them now. HTH. -- Backer boards, stop blocks, build oversized, and never buy a hand plane-- |
#9 posted 729 days ago |
I just picked up a pair of these in the 10 inch size. Haven’t had a use for them yet, but for $20 for the pair I couldn’t say no. I too have the “which way is in and which way is out” problem, but don’t really care as a couple of turns the wrong way show up pretty fast. -- The nicer the nice, the higher the price! |
#10 posted 729 days ago |
You can clamp things with them ,where no other clamp will. And they can apply a great amount of pressure -- E J ------- Always Keep a Firm Grip on Your Tool |
#11 posted 727 days ago |
I send a small clamp home with all new guys and tell them to play with it tell instinctive . the arrows are a great idea.Lefty loose, righty tight, keep your tork even, and set your clamps on a glue up to close to what will need in width before gluing. Radiuswoodguy.com -- Radiuswoodguy |
#12 posted 726 days ago |
They are my favorite type of clamp. You can buy them at Harbor Freight for very little money. |
#13 posted 724 days ago |
Righty tighty lefty loosey unless it’s a left hand thread then you are in deep doo doo. I can’t see as it matters at all given that there is no real harm you can do by pushing the handle around that tiny scosh to know whether it’s tightening or loosening. In the machine shop that type of clamp is called a “parallel clamp” because of the ability to set the jaws as true to parallel or not as you please. -- When the moderator chooses sides, his site sucks. |
#14 posted 723 days ago |
Yes, they are great clamps for clamping small peices or uneven peices. If you use them enough you will not even think about which way to turn them -- Owner of custom millwork shop |
| Forum | Topics |
Woodworking Skill Share
8794 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1534 |
3553 |
15801 |
Hand Tools
2038 |
Jigs & Fixtures
495 |
Wood & Lumber
2842 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6162 |
