Comment/question for those of you that use the Deulen sharpening jig
Forum topic by garageking posted 04-26-2018 03:17 PM 1498 views 0 times favorited 5 replies Add to Favorites Watch
View garageking's profile
garageking
32 posts in 502 days
04-26-2018 03:17 PM
Topic tags/keywords: deulen jig jointer knife sharpening
I recently purchased the Deulen jig to sharpen my jointer knives.Having watched the youtube videos I pasted sandpaper onto glass and made sure I did the same number of strokes for each knife. As expected the sandpaper is probably only good enough for one set of knives (if that). But while very impressed with the jig (beautiful tool well worth the money), I wasn’t happy with the sharpness of the knives.So I reverted to what I do with very dull chisels or plane blades ie lay the sandpaper on the jointer table and slowly progress to higher grits (and much higher than the 400 Mr. Deulen recommends).I also made sure to flatten the back of each knife first. I also didn’t get too hung up on putting the same number of strokes on each knive (what does it really matter if the tip of each knife is going to be individually set at the level of the outfeed table or a couple of thousandths above). I use the Oneway multigauge. Using this technique (basic scary sharp), I was able to nicely shave my arm.To return to the jig itself, it was made of spalted (maple I think) and really nicely machined brass. So I do highly recommend it.
-- David, Kentucky
5 replies so far
View Bill_Steele's profile
Bill_Steele
361 posts in 1783 days
#1 posted 06-20-2018 02:00 PM
I have this jig in the 12” size—I think mine is made of oak—but I might be mistaken. I have used it once or twice to sharpen my planer knives. It was a while ago but I think it did a decent job of sharpening the knives—probably not “scary” sharp—but sharp enough to perform well. With the 12” size I can also put all three 6” jointer knives in at the same time (2 on one side and 1 on the other). It’s not something I use often.
Unrelated question—should I be striving to get my jointer and planer knives sharp enough to shave with? Sometimes I wonder if a really sharp edge may not be very durable.
View Aj2's profile
Aj2
1497 posts in 1850 days
#2 posted 06-20-2018 02:20 PM
Bill after using that jig have you checked to see if the edge is straight. No belly or hollow in the middle.
I tried to make one and the blades always came out wonky
So I use a tromek to sharpen my jointer knives keeping the sharpness angle is very important. To compliment the hook angle of the head. A straight edge is also nice easy setting
-- Aj
View Andre's profile
Andre
1922 posts in 1858 days
#3 posted 06-20-2018 02:28 PM
Check out this method of getting scary sharp blades?
http://lumberjocks.com/projects/106720
Have since switched to carbide helical head machines but sometimes miss the perfect finish the Hitachi used to leave!
Bill_Steele
#4 posted 06-20-2018 04:09 PM
Aj – I did not put a straight edge on the knives—I’ll have to check them. The jig has a brass insert that I assume has a flat bottom. It’s probably important to make sure that the knife is fully seated in the insert. I imagine if the slot was not completely flat that the knife might rock or more might get taken off one end than the other.
Those Tormek sharpeners are very nice and I’d like to get one someday. For now all my sharpening is done by hand with jigs (Deulen and Veritas) to help support and align.
Bill_Steele
#5 posted 06-20-2018 04:18 PM
Andre—that’s a nice jig. I like that you can take a sharpening stone/plate to the knife and use a smaller stone—rather than having to have a large base made of float glass/granite/MDF with sandpaper.
