Milling a table saw miter slot.
Forum topic by rwe2156 posted 04-26-2018 03:15 PM 569 views 0 times favorited 8 replies Add to Favorites Watch
View rwe2156's profile
rwe2156
3073 posts in 1601 days
04-26-2018 03:15 PM
Hey guys.
I have added the table saw on the right to my shop. Quite disappointed to find 1) the miter slot is every so slightly narrower 2) quite a bit wider apart, rendering both my Jessem miter gauge & xcut sled unusable on it.
Came across https://www.youtube.com/watch?v=Urz57RVC15A on YouTube and was thinking about trying it.
At least I would be able to use the miter gauge and my single runner jigs.
What do you guys think?
Or is there another way to do it? The slot is about .010” narrower.
8 replies so far
View RobHannon's profile
RobHannon
148 posts in 651 days
#1 posted 04-26-2018 03:23 PM
How upset will you be if you mess up the miter slot?
I personally would try it but thats me. Cast drills and taps pretty easily, so in theory it should go fine with some prep and patience. Cutting cast will generate heat pretty fast, so id take lots of breaks and get a couple extra bits if you do commit to trying it.
View GR8HUNTER's profile
GR8HUNTER
4573 posts in 833 days
#2 posted 04-26-2018 03:47 PM
UUUMMMMMM i will be watching this as i hate my hole
View Loren's profile
10477 posts in 3768 days
#3 posted 04-26-2018 04:19 PM
You can try filing first to see what that’s like.
I wouldn’t be afraid to use the router
personally but of course you have to get
it right.
View HokieKen's profile
HokieKen
6178 posts in 1259 days
#4 posted 04-26-2018 07:54 PM
Problem with a router on metal is speed. Cast iron is pretty friendly but you’re continuously putting carbide into an interrupted cut at speeds much higher than appropriate. But, it’s only .010 so it’s probably not a real safety issue and may work just fine. I’d use a bit smaller than the slot though to avoid it getting hung on both sides and getting 2 rough edges.
Honestly if were me, I’d go with file and a carbide scraper. It’ll probably be faster when you factor in setup time and definitely less nerve-racking…
-- Kenny, SW VA, Go Hokies!!!
View GrantA's profile
GrantA
401 posts in 1528 days
#5 posted 04-26-2018 08:29 PM
File with a safe edge should take off.010 without too much grief.
View RobS888's profile
RobS888
2489 posts in 1965 days
#6 posted 04-26-2018 09:31 PM
Are the trunions table mounted? I’m asking because it looks like the gaps are reversed, sort of like the center table portion is reversed on the saw on the right.
-- I always suspected many gun nuts were afraid of something, just never thought popcorn was on the list.
View TheFridge's profile
TheFridge
10124 posts in 1606 days
#7 posted 04-26-2018 09:39 PM
Get a router speed control and go slow. I used a router sled to fix my potato chipped uni top and deepen the miter slots. Think I have a blog on it but it’s been awhile.
View John Smith's profile
John Smith
1312 posts in 283 days
#8 posted 04-26-2018 10:12 PM
I have accidently cut into a cast iron table saw top with my 2hp hand held router
with a 3/4” carbide tipped dado bit. it was about a 1/16” deep by 6” cut.
so I know that it can be done. if you use a router, you may have to
sacrifice the bit to get it done (on purpose).
I used Bondo Steel Epoxy to fill the gouge which worked quite well.
-- some people are like a Slinky - - - pretty much good for nothing. But still make you smile when you push them down a flight of stairs.
