| Forum topic by pashley | posted 610 days ago | 765 views | 3 times favorited | 40 replies | ![]() |
610 days ago |
Topic tags/keywords: sketchup I’ve been considering using Google’s free sketchup program to design my projects. I like the fact that you can print out templates and simply cut from them. Currently I use a 3D program called Bryce which does some great renderings, but you cannot print out templates, and measuring is a little weird. Some questions I had: 1) Once you do your “sketch”, can you export it to a popular 3D format, so that you can make a fine rendering in (in my case) Bryce? It seems the Sketchup renderer is a bit lacking here? 2) How steep is the learning curve? I’ve worked on computers for years. Any other thoughts would be appreciated…. |
610 days ago |
It doesn’t look like you can export 3D models, but there are some rendering plug-ins that do a much better job than the built-in rendering engine. You might be able to find a plug-in that will do 3D export, too. If you are used to modeling programs, I don’t think you’ll have too much trouble with SketchUp. Most people pick up on the basics really quickly. -- http://www.north40custom.com -- http://north40studios.etsy.com -- |
610 days ago |
I am far from computer illiterate, and somehow ScetchUp has beaten me at every turn. Your mileage may vary. |
610 days ago |
the free version does not allow exporting (Except to Google Earth). Here is a link to the files for the pro version. http://sketchup.google.com/gsu6/exporters.html As for the learning curve, It takes some time. I tried several other programs before landing onn this one. I still like it better. -- Scott - Chico California http://chicowoodnut.home.comcast.net |
610 days ago |
I have fiddled around with Sketchup a couple of times, but found the measuring lacking the accuracy I want. The 3D seems cool, but of no real value to me. I use a AutoCAD, and have never bothered with the rendering, since all I need is in 2D. Learning curve on most of these is prety steep, so since I know a number of keyboard shortcuts, I will stick with a standard type program. -- Paul from New England "No man is a failure who is enjoying life". William Feather |
610 days ago |
I think I might take a stab at it, and get a “for Dummies” book to help me out. Can someone point me to some renderings done with these plugins? I’d be interested in seeing them…. |
609 days ago |
It looks like a fair amount work (depending n your experience), but the common theme is to convert KMZ files to whatever you need, however you can: Blender is also a free 3D program, but don’t even think about just trying to guess how to use it ;) If all you’re doing is opening and exporting, it shouldn’t be too bad. -- Tom, Central New York |
609 days ago |
I’ve been trying to learn SU for a few weeks now… I have found it VERY FRUSTRATING… until I’ve learned how to handle my specific problem(s). I have been fortunate to run into a SU GURU on one of the forums who is willing to help me with whatever my problems whenever I have problems. He has helped me alot. I too have been working with computers since 1962, operating, programming, systems design, teaching, managing, etc. I have found SU to be very hard to learn… not very user friendly… my friend disagrees… I’ve almost quit using the programs a couple of times now… to rest, think about it, only to try it again… getting better and better each time. There are Tricks to it’s use… subtle tricks… still learning… getting better… I’m currently learning how to rotate (orient) and move components to create the Model. That Rotate tool can be SO frustrating, it’s enough to really “get” to one… I have alot to learn… the more I use it & learn, the more I like it. I have learned alot from this LINK… -- Have Fun! Joe Lyddon - Alta Loma, CA USA - Home: http://www.WoodworkStuff.net ... My Small Gallery: http://www.ncwoodworker.net/pp/showgallery.php?ppuser=1389&cat=500" |
609 days ago |
robertpaul~Lacking the accuracy you want- What are you building that you need better than a 64th? Ryan Edit: To change units: -- If you can't set a good example, at least serve as a horrible warning... www.rarewoodcreations.com |
609 days ago |
Sketch up is the best thing ever invented on the computer for woodworkers :) JC -- Somewhere, something incredible is waiting to be known. -Carl Sagan |
609 days ago |
Yes, I’ve seen the SU videos on YouTube, and I think they will help me. I guess it’s like any program – you have to learn it, the hard way. Wish Apple had made it; I’d have had the Queen Mary done by now… :) I’ll keep pecking away at it – I think it will be worth it in the long run. |
609 days ago |
As mentioned the free version will not export 3D models other than kmz for import to Google earth (pretty cool to play with that though) Clients think its pretty cool to zoom in on their project from outer space…:) The sketchup render is better than most people think. The key is to get good materials textures. There is an extraordinary bunch of wood textures at: I haven’t played with Bryce in years. I used to love the landscapes it would generate. There is a very good blog (Design, Click, Build) on Sketchup at Finewoodworking.com. I used to contribute to it (you’ll find some of my video tutorilas there) but dropped it when I found LJ. Tim Killen on FWW is doing some amazing design work with it. FWW’s online subscription is a must for any serious woodworker IMO, amazing knowledge base there. I’ve done a few tutorials for Sketchup here as well. Just look at my blogs. I’ll try to add some more and feel free to ask any questions. Probably best to PM me so I’ll be sure to see it. Sketchup is easy to learn for some and tough for others. I think it has to do with taking the time to view the tutorials avialable on the web and paying attention to the items that catch people. Sketchup has a very different way of creating geometry and its the subtle things that Joe mentions above that cause problems…stickiness and inference are just two that come to mind. One rule…you can’t make too many components. I make components of just about every piece in a design. Accuracy isn’t a problem. You can type in the exact accuracy you need for almost any command. One of my blogs here talks of setting up Sketchup for woodworking. I’ve said this many times and I’ll repeat it here. I have 30 years of design/drafting experience. I’ve used Autocad, Microstation, and other graphic and 3D design software professionally for over 20 years and use Autocad almost every day. I do all my woodworking design in Sketchup. Its the easiest and best software package I know of for creating accurate 3D designs. I have a plugin for Sketchup that extends its realism but don’t use it much. I have seen some very realistic things done with some but they aren’t free. The native renderer suits my purpose 90% of the time. Especially for woodworking. -- Bob, Carver Massachusetts, Sawdust Maker http://www.capecodbaychallenge.org |
609 days ago |
”There is a very good blog (Design, Click, Build) on Sketchup at Finewoodworking.com. ... (you’ll find some of my video tutorilas there) ...” That’s the guy that emailed me and is helping me alot! Dave Richards… a real expert / guru on SU! -- Have Fun! Joe Lyddon - Alta Loma, CA USA - Home: http://www.WoodworkStuff.net ... My Small Gallery: http://www.ncwoodworker.net/pp/showgallery.php?ppuser=1389&cat=500" |
608 days ago |
G.I.G.O. and additionally R.T.F.M. nuff said . . . |
608 days ago |
How about G.I.R.G.O.? What is R.T.F.M.? :) -- Have Fun! Joe Lyddon - Alta Loma, CA USA - Home: http://www.WoodworkStuff.net ... My Small Gallery: http://www.ncwoodworker.net/pp/showgallery.php?ppuser=1389&cat=500" |
608 days ago |
RTFM – Read the fantastic manual. At least I think that’s what the F stands for…. -- I am always doing that which I can not do, in order that I may learn how to do it. - Pablo Picasso |
608 days ago |
This page is titled “How can I best learn how to use Google SketchUp?” http://sketchup.google.com/support/bin/answer.py?answer=36211 Here is a link to the manual page. Sketchup frustrates a lot of people initially but once you understand the basic concepts it gets much easier. -- Bob, Carver Massachusetts, Sawdust Maker http://www.capecodbaychallenge.org |
607 days ago |
Thank you, yes, I was aware of those links. I have purchased “Google Sketchup for Dummies” and it seems pretty good, so hopefully, that will get me going! |
607 days ago |
Sketchup question: I’ve made a basic mission coffee table in SU. Can SU: • Print out a architectural – type plan, in which is shows the dimensions of each part, even though I have not used the Dimension Tool on each piece of the table? Or, do I have to dimension each piece, then print it out? • Can SU print out a list of the board feet I’ll need for this project? It would be great if it would do a cutting layout on boards as well, but I doubt it can. Thanks! |
607 days ago |
Another question: how do you “explode” your project? |
607 days ago |
You’ll need to dimension the pieces seperately using the dimension tool. I talked about this in a previous post. You’ll find it here. http://lumberjocks.com/topics/991 Unfortunately the estimating tool in Sketchup is not very useful. There is a cost estimator under the Plugins menu. You assign a cost to a material/texture and then can calculate the total cost based on selected faces but it is rudimentary at best. No cutting layout either. There are some specialized cabinetry software out there that will do those kind of operations but I haven’t used any. Mostly pros using them. As for cut layouts I have done it manually in Sketchup but its not much faster than figuring it out yourself. Tim Killen has a great blog on doing that on FWW. -- Bob, Carver Massachusetts, Sawdust Maker http://www.capecodbaychallenge.org |
607 days ago |
Exploding the project may be too grand a term. As I make each individual piece I make a component out of it. Once everything is designed I make a copy and then simply move the pieces away from each other. Seperate them enough to allow for easy dimensioning and printing. -- Bob, Carver Massachusetts, Sawdust Maker http://www.capecodbaychallenge.org |
606 days ago |
Pashley, |
606 days ago |
Does anyone know why, when I export my SU file in 2d to a jpg format and then try to view it all I get is a black screen? I had this issue before and I can’t remember what I had to do to resolve the problem. -- Canadian Wood Chuck (Bruce) |
605 days ago |
Question: Let’s say I’m using SU to lay out a mission table. I want to make a tenon joint. I can understand how to make a tenon on the end of a piece, but how do you automatically make the mortise draw on the post? |
605 days ago |
You draw the outline of the mortice on the surface where it will be located, and then use the “Push/Pull” tool to “push” the mortice into the post the desired amount. Again, ‘automatically’ is more a measure of degree of work involved (one man’s ‘automatic’ is another man’s ‘magic’!). I’ve been using SketchUp since Version 2, and I can say without reservation that the tutorials are indispensible to learning the tool. There are a lot of things you can do “brute force” that take a long time, which take only a few keystrokes after learning from the appropriate tutorial. Yes, it’s like scheduling a dental appointment or sitting down to review your insurance coverage. You know you need to, but you just don’t want to stop and spend the time. You will be amazed, though, at the future hours you’ll save for having taken the time for the tutorials. And, since you’re very familiar with computers, you will gain even more benefit. Aside from the tutorials the things that most help me in efficiently using the tool are: a five-button mouse, setting up the blank SU page to a template of my choosing by using all the “Preferences” and “Model Info” features, and using the numerical keypad to enter all lengths and sizes, rather than trying to make the mouse a pencil. As grumpycarp has pointed out, the ‘Free’ version won’t do everything that the ‘Pro’ version will, but it does most of it, and ‘Free’ is about as good a deal as you can get to sample and learn the program prior to making the decision to buy. Good luck! -- Earle Wright, Lenoir City, Tennessee |
605 days ago |
Thanks, Earle, I think I’m half way there….let me further clarify. Let’s say I have a tenon made on the end of a piece of maple. It’s 3/4” wide by 4 inches high. I’m going to be putting this tenon in a mortise on a 4×4 leg. I know how to take the tenon and place it on the leg right where I want it. Now, I want SU to automatically “cut” that mortise in the 4×4 leg - how to do that? I’m guess it has to do with the “Intersect with Model” command? If that is the case, do I need to make that tenon, and the piece of maple it’s on, a Group first? |
605 days ago |
The most important things to me in Sketchup: 1. Make sure you GROUP EVERYTHING (otherwise parts will “fuse” together when they touch) -- Tom, Central New York |
605 days ago |
I think I understand what you’re trying to do. I just set up a simple SU file to try to accomplish what you want, but have so far been unsuccessful. I may play around with it a little more, because it seems that the “Intersect” tool should be able to handle this. Ain’t got it yet, though. Will let you know if I figure it out. After ‘soapboxing’ the tutorials so much, I’ll probably find the answer in one I’ve either not sampled or one I’ve forgotten about! If we (the LJ community) can figure a way to simply do it, though, it will be a very useful ‘routine’. -- Earle Wright, Lenoir City, Tennessee |
605 days ago |
The whole mortice thing…..make your tennon, save it as a component. make your piece that is getting the mortice, save is as a component. Partially insert the tennon where you’d like the mortice, then click “Intersect with model”. It will mark the mortice location. What I can’t figure out how to do is make compound curved legs…like what is on the Japanese box in my projects…anyone have any ideas? -- If you can't set a good example, at least serve as a horrible warning... www.rarewoodcreations.com |
605 days ago |
I’ve done tutorials on both the use of the intersect to create a mortice and tenon and on compound curves. Mortice and tenon…2nd tutorial in this set here Compound curve tutorial is near the bottom in the comments Do you folks subscribe to FWW online? I have a few other tutorials there. I’ll get them onto youtube and post them here soon. The one for a cabriolet leg will give you a good idea of the organic component creation. -- Bob, Carver Massachusetts, Sawdust Maker http://www.capecodbaychallenge.org |
605 days ago |
Patrick, Based upon what you’re wanting SU to do, I’m convinced (at this point, at least) that SketchUp won’t perform that function automatically. There are several ways to transfer the location for the mortice as you, Ryan, and I have pointed out. To make the mortice at that location, though, will require the “Push/Pull” tool. The reason for this is that all ‘solid-appearing’ objects are just ‘skins’ in SU, or collections of surfaces. There are no actual solid figures. So by ‘Intersecting’ the tenon with the leg, you are only marking the common points between the two, which are on a surface. Thus, the creation of the “Push/Pull” tool. I’m with Tom and his five rules. I want to use the tool as efficiently as possible, realizing its limitations and well as its ‘features’. -- Earle Wright, Lenoir City, Tennessee |
605 days ago |
The feedback I’ve been getting here and elsewhere, is that this can’t automatically be done. BUT, i have figured out a way to do it! I should probably make a video…. |
605 days ago |
By automatically do you mean the tenon will create the mortice as soon as you put the two together? If so…no it won’t. I slightly disagree with the 1st two of Tom’s rules. 2. I rarely use construction lines. With the absolute accuracy available and inference snapping I think they are usually an unneccesary step. ie: This model of the filters for a 140 MGD water treatment plant is precisely accurate. All the concrete work, piping, etc.. was done without the use of construction lines. -- Bob, Carver Massachusetts, Sawdust Maker http://www.capecodbaychallenge.org |
605 days ago |
I believe I have come across a good way to do this mortise/tenon thing I alluded to earler. I made a video of it, which can be seen here: |
605 days ago |
Nice adaptation….using the intersect and erasing unneeded parts is key to the creation of more complex geometry. The original sketchup tutorials on sketchup.com use it often. I just added a few tutorials to my blog that you folks may be interested in. The one for the cabriolet leg is a good example of using intersect to create something that would otherwise be very difficult in sketchup. http://lumberjocks.com/jocks/Treefarmer/blog/4011 -- Bob, Carver Massachusetts, Sawdust Maker http://www.capecodbaychallenge.org |
601 days ago |
I have used turbocad before sketchup. I think SU has a faster learning curve and is more user friendly but I still use both. -- Grumpy - "Always look on the bright side of life"- Monty Python |
598 days ago |
A few thoughts… The tape tool is a handy item but you will find that as you become more adept at using SU you will use the VCB more than the tape tool. But that being said, construction geometry can be very useful to align rotate and move parts. Put them on their own layer and then you can hide them when you don’t need them. Also, as someone else stated above, set up and use keyboard short cuts. They can speed up your drawing time. A big one I use allot is hide and unhide. It is soo much easier and faster to choose an entity and just press “H” on the keyboard, rather than use the right click menu. I very rarely use icons. As far as rendering is concerned, I don’t really consider the native SU output as renders…more drawings then renders in my opinion. To me the term render really means photo realistic rendering, although in the old school hand drawing days a render could be a pencil sketch, or a watercolor or marker colored drawing, but the intent was to represent the object in a realistic light. If you want to get realistic results within SU, then look into Podium. It is a photo realistic render ad on that plugs right into SU. It is pretty easy to use once you read through the documentation and get a grasp on the basics. The thing that really sets it apart from all the other render engines and plug ins is the interface. It isn’t a sea of buttons and click boxes with functions that you don’t understand. It is easy to use but it has some advanced capability’s and support like bump maps, clip maps, and the ability to create light emitting modules (LEM) and omni lights. Like SU it takes some practice and fooling around with it to get some really killer results. The demo version is free and is fully functional, but the output is limited to smaller size renders. It is reasonably priced, and the support is great with an on line message board community allot like here..a bunch of great people that will not hesitate to help anyone. Same model and file, simple ambient light render using Podium.. Hope that helps.. -- David, South Windsor, CT "I love the smell of sawdust in the morning" |
598 days ago |
Thanks, David. I am getting the hang of SU, and like any program, you just have to take the time to learn it! |
595 days ago |
Hi David, I need to take a look at podium. I have turbo sketch but I’m not very happy with it. Takes forever too. I’ll get some more pics of the plant posted shortly. What you see there is the heart of the plant but justa small portion of the whole model. I have some interesting sections especially. I have 100’s and 100’s of hours into it. I just completed a walkthrough animation of the renovations that I’ve been designing. One thing I hope they improve in Sketchup is the animation capabilities. I’ve gotten pretty good with the limited tools but its still a pain. -- Bob, Carver Massachusetts, Sawdust Maker http://www.capecodbaychallenge.org |
589 days ago |
Bob Babcock, those videos are awesome! I have learned a lot of how to use Sketchup, and I am happy with my skills, and then I see these videos and realize how little I know of the program’s capabilities. Thanks for putting them up. If you feel compelled, I would like to see some more. -- There are three kinds of people... those who can count, and those who can't |
| Forum | Topics |
Woodworking Skill Share
2904 |
3923 |
256 |
943 |
222 |
Woodworking Trade & Swap
617 |
Coffee Lounge
2371 |
LumberJocks.com Site Feedback
522 |
