Dowels- Build 'em or buy 'em
Forum topic by Jakes7196 posted 04-24-2018 01:05 PM 720 views 0 times favorited 15 replies Add to Favorites Watch
View Jakes7196's profile
Jakes7196
1 post in 275 days
04-24-2018 01:05 PM
Hello Gang,
I’m kind of new to wood working and I’m embarking on my first project utilizing dowels.
I’m wondering if you guys cut your own from dowel rods or buy the ones that are already fluted. I would round the edges for easier insertion, but don’t really have a good way to flute them. Is it a big deal if they are just solid pieces?
Thanks for the advice.
15 replies so far
View Lazyman's profile
Lazyman
2711 posts in 1629 days
#1 posted 04-24-2018 01:20 PM
I don’t use dowel joints often so I usually just use use whatever dowels of the right size I have in the shop and cut them to length when I need them. You can usually get by with the flutes which I think are there to allow excess glue and air to escape more easily as you tap them in and clamp the joint. If that is a problem, you can just sand or plane a slight flat on one side. If you are using a bunch it is easier to do that before cutting to length.
View DanK's profile
DanK
26 posts in 2909 days
#2 posted 04-24-2018 01:51 PM
I would buy them myself, but I know that they can be made using the jaws of a pair of pliers. Crimp and turn.
Or try a homemade jig:
http://www.rockler.com/how-to/build-fluting-jig-wooden-dowel-rods-drywall-screws/
View JADobson's profile
JADobson
1337 posts in 2352 days
#3 posted 04-24-2018 02:28 PM
I’ve only done one project with dowel joints and I just used normal straight dowels, no flutes. 6 years later its still together.
-- No craft is very far from the line beyond which is magic. -- Lord Dunsany — Instagram @grailwoodworks
View Nubsnstubs's profile
Nubsnstubs
1435 posts in 1971 days
#4 posted 04-24-2018 02:34 PM
Jakes, when I first started my business back in ‘78, I bought both 3/8 & a 1/2”plug cutters that will also cut 2” long dowels. I think they were made by Forest City. Sometimes when I want to do a cabinet with all the same species, I’ll make dowels from the scraps.
IMO, air is going to escape from the wood no matter what, but too much glue will give you a problem. Oak is the best example as I’ve had glue come out of the pores onto the surface of the wood.
I made a tool to insure that the dowel hole is completely covered in glue and haven’t had a problem. This tool is nothing more than a stick with a 3” screw in the end of it that the head is the same diameter of the hole. Push it in, glue curls up around the screw head, and when you pull it out, it smears the inside of the hole, and any leftover glue on the screw head goes into the next hole.
In conclusion, make your own dowels until you get tired of it, then start buying them.
If you do get some dowel cutters, they can also be used to make plugs that are used to cover screw holes and such. ............. Jerry (in Tucson)
View pintodeluxe's profile (online now)
pintodeluxe
5820 posts in 3055 days
#5 posted 04-24-2018 02:39 PM
Dowels are only occasionally the right joinery choice for me. I never use them as the main structural support for a piece of furniture, but they can be handy to attach a corbel etc.
I usually use pre-made fluted dowels, but have also used 5/8” dowels made from oak dowel stock. Both work well.
View Underdog's profile
Underdog
1250 posts in 2277 days
#6 posted 04-24-2018 02:45 PM
I buy ‘em unless I can’t find the size or species I need. OR… if the only ones I can buy are crappy…
Then I either turn them to size on my lathe, or build a jig. But I haven’t had to make a dowel in quite a while.
-- Jim, Georgia, USA
View Gene Howe's profile
Gene Howe
11167 posts in 3670 days
#7 posted 04-24-2018 02:48 PM
I know that lots of people use dowels in lieu of other joinery techniques. I find them too time consuming to do correctly. I do use them to cover screw holes. Like Jerry, I cut my own to get a match.
View Loren's profile
10477 posts in 3889 days
#8 posted 04-24-2018 04:22 PM
Dowel rod you buy at hardware stores isn’t
round. I think it’s cut on some kind of shaper,
not a lathe. You can pound it through a dowel
plate to make it round.
I buy dowels. They are cheap if you shop around
but they might not seem that way if you’re
looking at little bags in a hardware store.
They do move seasonally in size which can cause
problems. I’ve tried keeping them in plastic
with a desicant bag. If they are too tight you
can make a “shop oven” with a coffee can and
a light bulb shining down into it – like one of those
EZ-bake ovens really. Over a few hours it will
reduce the moisture content and they’ll shrink
a little.
Fluted dowels hold glue in the grooves so it doesn’t
get scraped off when you insert them. I think
flutes are a good feature but if your dowels don’t
have them it’s not a dealbreaker. Only time will
tell if your joints hold up.
View Planeman40's profile
Planeman40
1333 posts in 3002 days
#9 posted 04-24-2018 05:21 PM
I love doweled joints! I prefer them to screws.
Not being a furniture maker, I use them to strengthen joints on a lot of other things that I don’t have to worry abut the dowel heads being seen. My process is to first glue the joint and let it dry. Then I drill the dowel hole! Yes, you can see the dowel after it is worked flush with the surface, but I view this as proof of a secure and long lasting joint.
View caboxmaker's profile
caboxmaker
281 posts in 629 days
#10 posted 04-24-2018 07:12 PM
Dowels are the best. Stronger than MT.
View BlasterStumps's profile
BlasterStumps
1079 posts in 681 days
#11 posted 04-24-2018 07:38 PM
If you have a dowel plate, you can pound through a few out of the wood of your choosing. That can make your project a little nicer if the dowel is either same material as the other wood or, in other cases a contrasting wood.
-- "I build for function first, looks second. Most times I never get around to looks." - Mike, western Colorado
View bondogaposis's profile
bondogaposis
5156 posts in 2593 days
#12 posted 04-24-2018 08:47 PM
For dowel joinery, definitely buy them, they are cheap. If you are using them for plugs or other visible purposes, then get plug cutter and make your own.
-- Bondo Gaposis
View AlaskaGuy's profile
AlaskaGuy
5002 posts in 2550 days
#13 posted 04-24-2018 08:48 PM
- caboxmaker
Never had a M&T joint fail (or Domino) so it a moot point to me.
runswithscissors
2928 posts in 2266 days
#14 posted 04-27-2018 12:57 AM
There is an important difference between plugs and dowels. Plugs have the wood grain running across, rather than the long way. Looks better when you install them if the grain parallels the wood of the piece you’re inserting them into. They are much easier to cut or sand flush than a dowel. I usually cut them almost flush with a sharp chisel, then finish by sanding.
They’re easy to make with a plug cutter, and preferably a drill press. They can be broken out one by one with a knife or screwdriver, or run the donor board through a saw so they all pop out together. Unfortunately, on a TS they are likely to spray all over the place.
A plug would be entirely inappropriate to use as a dowel. No strength at all.
View Dave Polaschek's profile
Dave Polaschek
3098 posts in 823 days
#15 posted 04-27-2018 01:21 AM
I need dowels, I rive them out of a piece of wood, round them a little with a spokeshave, then bang them through a dowel plate. But then I drawbore stuff and generally want straight-grain oak or ash dowels.
-- Dave - Minneapolis
