Small Jointer, long timber
Forum topic by flapjack posted 04-24-2018 01:04 PM 658 views 0 times favorited 10 replies Add to Favorites Watch
View flapjack's profile
flapjack
1 post in 268 days
04-24-2018 01:04 PM
Hi Guys,
I have relatively small jointer (small shop) – the two beds are 14 inch each, so a total length of 28 inch. The problem is I need to straighten up a few 8 foot battens. Is it possible to do on such a small jointer ?
The types of warps on the battens include bows, cups, and twists.
10 replies so far
View hokieman's profile
hokieman
192 posts in 3989 days
#1 posted 04-24-2018 02:02 PM
As James Comey would say, “I don’t think so, but it’s possible”. Even with a jointer with longer beds it is difficult to get a good cut at the lead and trailing ends of the material given the large amount of weight on both extending ends. With a jointer as small as you describe, it would be very difficult. Depending on how accurate you need to be you might want to consider taking it to a mill and have them do that part of the project for you.
View Lazyman's profile
Lazyman
2703 posts in 1623 days
#2 posted 04-24-2018 02:19 PM
I have see a few jointer bed extensions projects posted on LJ to so that they can joint longer boards on a small jointer. Use the search function in upper right corner of page to find them. You may have to look for jointer extensions or outfeed support. You’ve got to make it so that the extensions are perfectly aligned with the tables which may limit your ability to easily change the depth of cut but that is one way to tackle that problem without replacing the jointer.
The other option is take it somewhere where for a small fee they will do this for you…or find a nearby LJ who will do it for free.
Welcome to Lumberjocks by the way.
View rwe2156's profile
rwe2156
3230 posts in 1716 days
#3 posted 04-24-2018 06:51 PM
I use roller stands for both in and out feeds to support ends of boards.
Its still not a straightforward process.
View HokieKen's profile
HokieKen
7524 posts in 1374 days
#4 posted 04-24-2018 07:15 PM
Lots of skill involved in jointing timbers that long. Even with in/out feed supports. I tried to figure out how to make it work… once. Since then a handplane is faster work with much less waste for me. I understand that hand planing isn’t for everyone but there are also router sleds you can make to flatten a face or sleds you can make to use your planer as a jointer.
The latter solution (planer sled) has worked well for me often. But, the longer and heavier the wood is, the less effective it is. My planer sled is like this one:
Click for details
-- Kenny, SW VA, Go Hokies!!!
View splintergroup's profile
splintergroup
2500 posts in 1458 days
#5 posted 04-24-2018 09:01 PM
For something like that, I’d double-sided tape it to a square strip of plywood and let the table saw make a straight edge (assuming that at least one edge/side/surface is already flat).
View bondogaposis's profile (online now)
bondogaposis
5149 posts in 2586 days
#6 posted 04-24-2018 09:17 PM
The general rule of thumb is that the maximum length of board you can straighten on a jointer is twice the length of the jointer bed. With that in mind you are going to need some auxiliary infeed and outfeed supports in order to joint 8 ft boards on your jointer. Others have given you some good suggestions.
-- Bondo Gaposis
View Loren's profile
10477 posts in 3883 days
#7 posted 04-24-2018 09:40 PM
You’ll do best with at least some accurately
leveled outfeed support. If the boards aren’t
heavy they are easier to hold pressed against
the outfeed table as the cut nears the end
and the weight is cantilevered.
View Kelster58's profile
Kelster58
670 posts in 775 days
#8 posted 04-25-2018 12:45 AM
For something like that, I d double-sided tape it to a square strip of plywood and let the table saw make a straight edge (assuming that at least one edge/side/surface is already flat).
- splintergroup
I agree, I would use my table saw and a plywood sled to true those boards up.
-- K. Stone “Tell me and I forget, teach me and I may remember, involve me and I learn.” ― Benjamin Franklin
View tomsteve's profile
tomsteve
896 posts in 1454 days
#9 posted 04-25-2018 03:08 PM
might be wise(and easier) to see if theres a cabinet shop, lumber supplier, another woodworker nearby with a larger jointer to take them to.
View LittleShaver's profile
LittleShaver
454 posts in 855 days
#10 posted 04-25-2018 05:26 PM
I did 14’ mahogany boards with hand planes. Don’t own a jointer. A long straight edge comes in handy. I used an 8’ piece of angle iron. After the edge was done, I flattened one face with hand planes and then ran them through the planer to get to final thickness. If i recall, they started at 6/4 and ended up about 1 1/8”. Did I mention the boards were 12-14” wide? Lots of heavy lifting and long in/out feed tables helped.
-- Sawdust Maker
