Need a 1.75" round over router bit
Forum topic by yellowtruck75 posted 05-24-2011 02:54 AM 4867 views 0 times favorited 18 replies Add to Favorites Watch
View yellowtruck75's profile
yellowtruck75
469 posts in 3089 days
05-24-2011 02:54 AM
I am looking to round over a 1.5” square piece of wood into a round piece without a lathe. Anyone know where I could get a 1.75” round over bit so that I can turn 1.5” square into a dowel rod?
Thanks
YT75
18 replies so far
View Loren's profile
10476 posts in 3670 days
#1 posted 05-24-2011 03:20 AM
Try Magnate. I’ve bought unusual bits from them in the past.
http://www.magnate.net/
There are other ways to make wood round. You can make rods
with a simple table saw jig. I think it’s a bit slow, but requires no
tooling you don’t already have.
The cut can also be arranged with a moulding head in the
table saw.
View Ripthorn's profile
Ripthorn
1458 posts in 3007 days
#2 posted 05-24-2011 03:23 AM
Pardon my dumb question, but wouldn’t you want a 3/4” radius bit? Those are much easier to find.
View ChuckV's profile
ChuckV
3123 posts in 3550 days
#3 posted 05-24-2011 03:25 AM
I might not understand what you are asking. If you are starting with a square that is 1.5” on a side, it seems that you want a roundover bit with radius half that, 3/4”.
How do you plan to support the piece after you have rounded some of the corners off?
-- “Big man, pig man, ha ha, charade you are.” ― R. Waters
yellowtruck75
#4 posted 05-24-2011 03:34 AM
Now that I think about it I guess that I would only need a 3/4” bit to round over a 1.5” square. Four sides rounded with a 3/4” bit will give me a perfectly round piece, correct?
View dbhost's profile
dbhost
5723 posts in 3254 days
#5 posted 05-24-2011 03:39 AM
Okay, dumber question. Why not start with a 3/4” dowel?
View rcs47's profile
rcs47
190 posts in 3152 days
#6 posted 05-24-2011 03:54 AM
Yellowtruck – yes, the 3/4” radius bit will give you a 1.5” round rod out of a 1.5” square blank when you adjust it correctly. I would not want to make the full cut at one time because you are taking a lot of material off. You can draw a curcle on the end of the rod to see how much of the corner you can cut off at the table saw (a 45 degree cut), then you should be able to cut the radius in one pass. Try it on a sample.
Good luck,
Doug
-- Doug - As my Dad taught me, you're not a cabinet maker until you can hide your mistakes.
View jeepturner's profile
jeepturner
939 posts in 2815 days
#7 posted 05-24-2011 03:57 AM
You might want to look at the following links,
http://www.woodsmithtips.com/2010/07/08/making-dowels/
http://lumberjocks.com/topics/193
With the second link you can use a a lot of different bits.
-- Mel,
ChuckV
#8 posted 05-24-2011 04:06 AM
If I were to use the method from Woodsmith, I would use a stop block on the fence to hold the piece from flying to the right as it is rotated into the bit. I might also use one on the left side of the fence where I want to stop.
Be safe.
View bubinga's profile
bubinga
861 posts in 2690 days
#9 posted 05-24-2011 04:13 AM
As rcs47 says ,see how much of the corner you can cut off at the table saw, I take off the corners of square stock, when getting ready to turn it on the lathe. I t saves time ,and ware and tear on ,bit and router, in that situation
You can use feather boards,and push stick to keep hands safe
-- E J ------- Always Keep a Firm Grip on Your Tool
View William's profile
William
9949 posts in 2865 days
#10 posted 05-24-2011 04:16 AM
I have tried making dowel rods in the way that you are talking about. I got the bejeebies scared out of me. Good luck. Let us know how it turns out. It may be able to be done safely if you had a way of holding it to keep your fingers away from moving sharp objects, like router bits.
bubinga
#11 posted 05-24-2011 05:25 AM
Ya now what ? bentlyj
I must agree with you here , don’t know what I was thinking, actually I am hungry and thinking about FOOD
I would rather leave the full 1 1/2” flat ends on the extra and make a few passes to remove the material instead,
I will go fuel my brain
View richgreer's profile
richgreer
4541 posts in 3097 days
#12 posted 05-24-2011 02:26 PM
The 3/4 bit will do the job, but I have a suggestion.
If possible, cut your 1.5” stock 3-4” longer than you need. Then, when routing, start you cuts in an inch or so from the end and stop the cut an inch or so from the other end. This will leave the ends square and it will be easier to control on the last cut.
When done, cut the ends off.
View Pick's profile
Pick
30 posts in 3055 days
#13 posted 05-24-2011 03:36 PM
I second Rich’s comment.
13606 posts in 3363 days
#14 posted 05-24-2011 03:48 PM
for this i always have a fence
that last corner
likes to cut in further
because the pilot is over on the first radius
by a bit
so it leaves a circle
with some out of round and a line
where they come together
i’m with rich and pick too
leave some square
so it doesn’t roll around
View wiswood2's profile
wiswood2
1138 posts in 3718 days
#15 posted 05-24-2011 04:08 PM
Leave each end sq. for a couple of inches.
Chuck
-- Chuck, wiswood2 www.wisconsinwoodchuck.com
