Question about plug \ receptacle for jointer
Forum topic by BalsaWood posted 04-21-2018 09:29 PM 398 views 0 times favorited 4 replies Add to Favorites Watch
View BalsaWood's profile
BalsaWood
68 posts in 1393 days
04-21-2018 09:29 PM
The JET jointer I just got says it requires a 230 V connection but not sure if that would work with the 6-20 receptacle I have. Can I use 6-20 plugs and 6-20 receptacle for the jointer even though the manual says to use 6-15 plugs and a 6-15 receptacle?
View Firewood's profile
Firewood
567 posts in 1869 days
#1 posted 04-21-2018 09:39 PM
Yes. You can connect via 20A circuit. It is just saying the minimum requirement is 15A. Make sure to use #12 wire for your runs.
-- Mike - Waukesha, WI
View jonah's profile
jonah
1971 posts in 3533 days
#2 posted 04-22-2018 12:10 AM
Be sure you get a 6-20 and not a 5-20. 6-20 is rated for 250V, and that’s what you need. I made that mistake once because they look the same, a 5-20 was in the wrong bin at the store, and I didn’t check it carefully when I pulled it out of the bin.
5232 posts in 2728 days
#3 posted 04-22-2018 11:37 AM
You’re good to go. Actually, most 6-20 outlets accept both 6-15 and 6-20 plugs.
BalsaWood
#4 posted 04-24-2018 08:49 PM
Hah- happened to me as well before reading your comment. Someone put a 5-20 in the 6-20 plugs section.
Be sure you get a 6-20 and not a 5-20. 6-20 is rated for 250V, and that s what you need. I made that mistake once because they look the same, a 5-20 was in the wrong bin at the store, and I didn t check it carefully when I pulled it out of the bin.
- jonah
