Resin pour
Forum topic by Ldc posted 04-21-2018 01:14 PM 528 views 0 times favorited 5 replies Add to Favorites Watch
View Ldc's profile
Ldc
14 posts in 1287 days
04-21-2018 01:14 PM
Topic tags/keywords: finishing
I want to build a resin table. I am looking for advise on type of casting resin to use. Some areas in my table wii be over 1” in depth. If you have done a resin table could you share some tips and advise.
Thanks
Larry
5 replies so far
View darthford's profile
darthford
612 posts in 2163 days
#1 posted 04-21-2018 03:03 PM
View John Smith's profile
John Smith
1554 posts in 402 days
#2 posted 04-21-2018 05:58 PM
one inch thick could produce a lot of exothermic heat.
if you are talking about deep pockets in the wood, I would pour them first.
a little at time, to build up to the level of the rest of the wood.
doing it all at one time could result in less than satisfactory or even catastrophic results.
I have used quite a bit of Castolite products back in the day with good results.
photos of your project would help a great deal with more accurate feedback.
-- I started out with nothing in life ~ and still have most of it left.
John Smith
#3 posted 04-21-2018 10:45 PM
Larry, just for clarification – - –
are you going to make a wooden table then pour resin over it like a bar top ?
or – a solid resin cast table with items embedded in it.
photos of your project will help a lot.
View Ldc's profile
Ldc
#4 posted 04-22-2018 11:24 AM
To clarify I am doing a solid resin cast table.
View squazo's profile
squazo
120 posts in 1884 days
#5 posted 04-22-2018 11:29 AM
https://m.youtube.com/watch?v=xfqY0DTPlVg
If the link doesn’t work YouTube “ocean epoxy table”
This will probably answer all your questions
