Hydraulic lift for mortiser under workbench
Forum topic by EdO posted 04-21-2018 01:01 PM 787 views 0 times favorited 10 replies Add to Favorites Watch
View EdO's profile
EdO
3 posts in 2271 days
04-21-2018 01:01 PM
Topic tags/keywords: shelf lift
Hi
I want to put my mortiser out of the way when not in use. I have space under my workbench, so I was looking for a hydrolic lift shelf so it would be easy to bring up to working height. My shop is small, so I’m looking for ways to conserve space. I found on at Home Depot for a lift for a mixer, but am looking for other options.
Thanks Ed
10 replies so far
View Rich's profile
Rich
4013 posts in 831 days
#1 posted 04-21-2018 03:16 PM
I made myself a rule a while back that if something was going to take up floor space, it had to include storage. For my bench top mortiser I build a 24×24 inch cabinet with three drawers and put it on locking casters. The mortiser is permanently mounted to it. When not in use I can roll it out of the way but still access the contents of the drawers.
View LesB's profile
LesB
1924 posts in 3685 days
#2 posted 04-21-2018 05:42 PM
Try a search of the internet for lifts. Also there are various designs for scissor lifts you could build yourself.
Another thing I have seen on this web site is multi purpose benches that have a top that rotates. You could use this idea and have your work surface flip over with the mortiser mounted on one side.
-- Les B, Oregon
View Loren's profile
10477 posts in 3889 days
#3 posted 04-21-2018 05:54 PM
I have a hydraulic lift table. It’s junk though.
The foot mechanism for loosening and tightening
the valve on the jack is beyond poorly designed.
I bought it used so I can’t really complain, but
just be aware the cheap ones may not hold up.
I had a 10” INCA jointer which is a small but
wide jointer that weighs about 160 lbs. I wanted
to stow it under the wing of my table saw and
pull it out and jack it up when I needed it. I think
the jack worked once or twice but after that it
wouldn’t lift the jointer. The table is still a decent
wheeled platform though and I just lift it up by
hand and stick a screwdriver in one of the holes to
lock the height.
One of these days I may get around to fitting it
with an Acme screw or something to make it
lift again.
View MrRon's profile
MrRon
5281 posts in 3485 days
#4 posted 04-21-2018 08:24 PM
I like the flip idea of Les B. It would provide a better support for a mortiser than a mixer lift.
View EdO's profile
EdO
#5 posted 04-22-2018 11:18 PM
Thanks for the ideas. I’m very limited on space and what I can do. I have one spot left that i could put a small stand like Rich mentions, but I was hoping to avoid having to use that space. I’ll let you know how it works out.
Thanks
Ed
View Mike_D_S's profile (online now)
Mike_D_S
558 posts in 2456 days
#6 posted 04-23-2018 04:07 AM
I’m not sure on the weight ratings, but I installed a sewing machine lift for my mom that felt pretty heavy duty. Might not be mortising machine weight rated, but had the right kind of motion.
Mike
-- No honey, that's not new, I've had that forever......
View squazo's profile
squazo
120 posts in 1887 days
#7 posted 04-23-2018 08:59 PM
You can get bottle Jack’s for 3 dollars at a pull-a-part junk yard. Maybee a floor jack could work.
View pintodeluxe's profile
pintodeluxe
5820 posts in 3055 days
#8 posted 04-23-2018 10:23 PM
I’ve had thoughts like this run through my head. In the end, I think it’s a neat concept to have a mortiser swing up and out of a cabinet, but it doesn’t really gain you any space. You’ll lose cupboard space to gain floor space.
I agree with Rich’s comment, a small cabinet on casters is the way to go. If you’re like me, I use the mortiser on every project.
View Lazyman's profile
Lazyman
2711 posts in 1629 days
#9 posted 04-23-2018 11:17 PM
If the mortiser can be attached upside down you may have the option of something that pivots under the bench or one of those portable tool stands with a flip top. Look at the grinder mount about half way down the page at the this link to the Family Handyman website.
View zzzzdoc's profile
zzzzdoc
550 posts in 3245 days
#10 posted 05-17-2018 06:16 PM
I went for the flip top portable tool stands, with my belt sander/disc sander on the other side. Still takes up floor space, but looks nice, and serves a double function.
-- Before you criticize someone, you should walk a mile in their shoes. That way, when you criticize them, you're a mile away and you have their shoes.
