| Forum topic by Marcel T | posted 199 days ago | 375 views | 0 times favorited | 8 replies | ![]() |
199 days ago |
199 days ago |
Probably not. If you are looking at a #10 1/2 Stanley, carriage makers plane you get similar properties. The 10 1/2 sells for quite a bit and the # 5, jack plane is pretty cheap. I would get both. Rebates can be cut with a plane but I’ve found that a router with the proper bit works better. -- Thos. Angle, Owyhee Design, Oregon |
199 days ago |
So no, I cannot use a rabbet plane as a jack plane? |
199 days ago |
Rabbet planes and jack planes are very different. A jack plane helps you prepare stock, whereas a rabbet plane makes rabbets (or rebates). You’d need both, I’d say. -- Eric at http://adventuresinwoodworking.com |
199 days ago |
Ok. I just thought that because they looked like they where the exact same plane, except that the rabbet had the iron extending all the way across the plane. |
195 days ago |
I have just returned from a class in using handplanes at Highland Woodworking in Atlanta. Although I am far from being an expert, the # 5 jack plane is a great all around workhorse. It will certainly serve well to flatten a rough sawn board in preparation for the planer. Even with my level of skill I could use it to joint the edges of boards up to about two feet long for gluing. Another very useful plane is the block plane, either with the standard angle of the low angle type. This is a great plane for smoothing edge grain, chamfering edges, trimming cabinet doors and many other tasks. Look for one with an adjustable throat. I have a Stanley # 60 1/2. Also demonstrated was an Anant # 78 Duplex Rabbet Plane with an adjustable fence for the purpose of cutting rabbets. Depending on just how far one wants to go into hand tool woodworking, it is possible to have a dozen or more planes. However, for a start, the #5 Lie-Nielson or the Clifton plane can’t be beat. They are expensive, at around $300, but are ready to go out of the box. Cheaper planes require a fair amount of tuning and work in order to get satisfactory performance. It goes without saying, if you get involved in handplanes, you will need some sharpening equipment. -- "Heaven is North of the Bridge" |
195 days ago |
Marcel |
195 days ago |
Thanks guys! You answered my question perfectly Philip, thanks again :) |
195 days ago |
Also, on a jack plane those strips on either side of the blade are part of the function of the sole. You cannot plane a groove into a board with a jack plane. It isn’t possible, which is good because your purpose is to flatten the board. The purpose of a rabbet plane is to put a groove into a board. The lack of a sole to each side of the blade allows you to do that job. -- Disappointment is an empty box full of expectation. |
| Sponsor | Forum | Topics |
Woodworking Skill Share
1218 |
1643 |
118 |
331 |
103 |
Woodworking Trade & Swap
232 |
Coffee Lounge
913 |
LumberJocks.com Site Feedback
268 |
