glueing hand cut veneer
Forum topic by paul burchell posted 05-22-2011 06:27 PM 1231 views 0 times favorited 3 replies Add to Favorites Watch
View paul burchell's profile
paul burchell
36 posts in 2624 days
05-22-2011 06:27 PM
Topic tags/keywords: veneering
I am going to build a small cabinet on stand using veneer,i already have the veneer sliced at 1/10” ,using some mdf edged with solid wood my question is what is the best glue to use,i don,t have a vacuum press i was just going to clamp it between some peices of ply
-- paul burchell
3 replies so far
View Loren's profile
10476 posts in 3677 days
#1 posted 05-22-2011 06:36 PM
With 1/40” veneer you can roll yellow glue onto both surfaces, let it dry,
then iron it on (just like edgebanding) with a household iron.
1/8” veneer will act a lot more like solid wood. Use a caul and clamps
or weights. Cinder blocks work.
View RickLoDico's profile
RickLoDico
55 posts in 3090 days
#2 posted 05-22-2011 06:47 PM
You can even water down the yellow glue by 50% and roll it on. After it dries, spray with water and iron on.
-- He who fights with monsters might take care lest he thereby become a monster. And if you gaze for long into an abyss, the abyss gazes also into you.
View DLCW's profile
DLCW
530 posts in 2683 days
#3 posted 05-22-2011 09:43 PM
Either yellow or white glue would work just fine. You could even use contact cement.
If it is a large surface and it is going to take a long time to spread the glue (starts setting up before you’re ready) you could use plastic resin glue (DAP Weldwood). This has about a 50 minute open time. But you will have to keep it warm using a heating blanket or something
-- Don, Diamond Lake Custom Woodworks - http://www.dlwoodworks.com - "If you make something idiot proof, all they do is make a better idiot"
