Jointer outfeed table too low
Forum topic by rrdesigns posted 05-21-2011 11:43 PM 1709 views 0 times favorited 9 replies Add to Favorites Watch
View rrdesigns's profile
rrdesigns
532 posts in 3386 days
05-21-2011 11:43 PM
Anyone know how to raise the outfeed table on a Powermatic 54A jointer? It is reading .026 below the highest point on the cutter head. I have tried using the handwheel with no success. It turns, but nothing happens to the table height. I loosened the limiting collet and the thumbscrew on the back already.
-- Beth, Oklahoma, Rambling Road Designs
9 replies so far
13640 posts in 3541 days
#1 posted 05-21-2011 11:51 PM
it may be at it’s limit already
maybe lower the cutters
rrdesigns
#2 posted 05-21-2011 11:55 PM
I don’t think the cutterhead height is adjustable. If it is, I don’t know how.
#3 posted 05-22-2011 12:05 AM
not the cutter head
(you are right it isn’t adjustable)
just the blades
rrdesigns
#4 posted 05-22-2011 12:11 AM
The blades are not the problem. The cutter head itself is. The outfeed table needs to be level with the highest point of both blade and cutter head. When the outfeed is too low, the wood rides over the high point on the cutterhead and actually leaves the infeed table ruining the operation.
#5 posted 05-22-2011 12:21 AM
the blades are made to be sharpened
so need to be adjustable up and down
if the body of the cutterhead is truly higher
than the outfeed table
maybe you need to get with powermatic about this problem
rrdesigns
#6 posted 05-22-2011 12:27 AM
Thanks for trying, Patron. I’ve already sent Powermatic an email. Awaiting a response. I’m hoping a fellow LJ might have run into the same problem so I don’t lose my weekend waiting.
#7 posted 05-22-2011 12:32 AM
the only other thing i can think of
is shims in the dovetail ways
for the table itself
not the best
but i’ve seen it done on worn jointers
and other tools
View jm82435's profile
jm82435
1285 posts in 3942 days
#8 posted 05-22-2011 01:29 AM
If you can spin the adjusting handle and nothing happens, it sounds like maybe the adjustment screw is probably either stripped (not probable) or is no longer engaged with the adjustment nut. My first thought would be to make sure it is not locked down in the back, or just stuck on the ways (gibs too tight?) as patron mentioned (probably need to loosen them with an 10mm wrench and 3mm hex wrench)
You can find the owners manual here:
http://content.powermatic.com/manuals/m_1791279DX.pdf
-- A thing of beauty is a joy forever...
#9 posted 05-22-2011 01:46 AM
jm may have a good point beth
when i was helping rand with his
that is what happened
we took everything apart and cleaned them well
(he used a wire wheel too)
and some smooth lube
and everything came good again
don’t know why i didn’t think of that
