florescent light won't work
Forum topic by Karda posted 04-18-2018 04:16 AM 819 views 0 times favorited 19 replies Add to Favorites Watch
View Karda's profile
Karda
1379 posts in 788 days
04-18-2018 04:16 AM
Hi, I have a 4’ florescent shop light and one of the tubes won’t work, thought it was lose but as i rote it it will flah at one point but it wont stay lit. I took it out and replaced it with the good bulb still didn’t work. Will one tube work or do you need 2. I took the light apart but did not see any lose connections. Any body have any idea what it may be. Could it be the ballast, it is an old light. Thanks Mike
19 replies so far
View mel52's profile
mel52
625 posts in 499 days
#1 posted 04-18-2018 04:55 AM
I am not an expert on these but almost sounds like the pin or whatever you have holders might be spread apart to far. When they are in the locked position they may not be making full contact. Might explain why they flash when turning. Just my two cents worth.
-- MEL, Kansas
View Loren's profile
10477 posts in 3882 days
#2 posted 04-18-2018 05:30 AM
I’ve read up on this a bit because I have the
same sort of thing going on with my lights. I
think the ballasts are the cheapest the makers
could get and that’s why they fail. I do have
one pricier fixture that has never acted up but
the cheaper ones I got for like $12 ea. years
ago at Home Depot are showing their age.
In my experience one tube will work. You can
sand the contacts with 220 or finer grit, that
can help with oxidation. I’ve done that on
dodgey magnetic switches with some luck.
Karda
#3 posted 04-18-2018 06:54 AM
thanks I was wondering if it was the ballast the light is old and cheap and they don’t last good. I was just hoping it was something simple. thanks for your help Mike
View Hermit's profile
Hermit
218 posts in 1559 days
#4 posted 04-18-2018 12:00 PM
Some of these lights will work with only one bulb and some will not. If you’re handy, just replace the fixture. By the time you’ve purchased bulbs then determine its the ballast, you’ve already spent the same as an inexpensive LED.
-- I'm like the farmer's duck. If it don't rain, I'll walk.
View Lazyman's profile
Lazyman
2700 posts in 1622 days
#5 posted 04-18-2018 12:37 PM
Sounds like the ballast to me. I’d replace the fixture with an LED one. It’ll be cheaper in the long run anyway because you’ll use less electricity and never replace the bulb again. I think that there are also some LED bulbs designed to replace fluorescent tubes where you have to remove the ballast first but not sure that those are any cheaper than just buying a new LED fixture.
View John Smith's profile (online now)
John Smith
1536 posts in 397 days
#6 posted 04-18-2018 12:39 PM
ballasts are cheap – remove one and take it to your local hardware store
to get a similar wattage replacement and two new “daylight” bulbs and you will be
back in business with nice bright lights.
-- I started out with nothing in life ~ and still have most of it left.
View Fresch's profile
Fresch
368 posts in 2155 days
#7 posted 04-18-2018 12:44 PM
Ballasts aren’t that cheap, dump it and go led daylight ~$20 ea.
woodbutcherbynight
5824 posts in 2643 days
#8 posted 04-18-2018 03:36 PM
Ballast cost same here locally as getting two quality LED’s drop ins for your current fixture. Once my stock of ballast and 200 bulbs is depleted I plan to convert all fixtures to LED. But that may be awhile. LOL Got my stock from the stockroom of a closed warehouse maint room years ago. For our favorite price of…. FREE.
https://www.homedepot.com/p/GE-120-Volt-Electronic-Ballast-for-4-ft-4-Lamp-T8-Fixture-93885/205409893
Karda
#9 posted 04-18-2018 05:32 PM
yea, I am going to replace it. I was just hoping thanks Mike
View Redoak49's profile
Redoak49
3731 posts in 2223 days
#10 posted 04-18-2018 05:39 PM
As my fluorescent fixtures are going out or bad, I am replacing it with LESs.
Karda
#11 posted 04-18-2018 05:47 PM
yea I like them better
View Dark_Lightning's profile
Dark_Lightning
3365 posts in 3343 days
#12 posted 04-21-2018 01:59 AM
- Redoak49
Exactly! I’ve tracked the lifetime of the fluorescent bulbs that I use, and the advertised lifetime of 7 years is complete baloney. They generally last less than 2 years. I’ve replaced 4 of 10 fixtures so far.
-- Random Orbital Nailer
Fresch
#13 posted 04-21-2018 02:03 AM
- Redoak49
Exactly! I ve tracked the lifetime of the fluorescent bulbs that I use, and the advertised lifetime of 7 years is complete baloney. They generally last less than 2 years. I ve replaced 4 of 10 fixtures so far.
- Dark_Lightning
How often do you turn them on and off? The rating is for continuous use, also the cheap China junk is… junk.
View MrUnix's profile
MrUnix
7102 posts in 2433 days
#14 posted 04-21-2018 02:07 AM
LED’s have a typical life of about 50,000 hours. However, the electronics that drive them, don’t.
View Nubsnstubs's profile
Nubsnstubs
1433 posts in 1964 days
#15 posted 04-21-2018 03:42 AM
LED s have a typical life of about 50,000 hours. However, the electronics that drive them, don t.
- MrUnix
Yep, a 120 watt Sylvania LED floodlight at 20 dollars each has a 20 year life expectancy. I’ll buy that, but it’s the other stuff converting the power that goes bad. Replaced 3 bulbs in less than three years. Fortunately Lowes guarantees them for 5 years. ............. Jerry (in Tucson)
