Installing shelf in upper corner kitchen cabinet
Forum topic by SiRiC posted 04-17-2018 01:19 AM 315 views 0 times favorited 3 replies Add to Favorites Watch
View SiRiC's profile
SiRiC
6 posts in 2074 days
04-17-2018 01:19 AM
Hi,
I am building kitchen cabinets and am using 24” angled front cabinets for the upper corners. As I was getting ready to assemble, I realised that I might not be able to get the shelf in after assembly.
Is it there a trick that I am missing or do I have to fit it in before I assemble?
Thanks
Steve
-- Measure twice...ummm.. i forget the rest!!
3 replies so far
View jbay's profile
jbay
2425 posts in 952 days
#1 posted 04-17-2018 01:51 AM
Should be able to get them in. Depends a lot on how you build the cabinet and face frame
(Stile width) (back thickness) (scribe space)
If I were you I would build the cabinet and before you put backs on (if you have backs) check to see if you can fit the shelf through the frame opening. You should be able to figure what to do at that point.
SiRiC
#2 posted 04-18-2018 01:32 AM
Will try that.
Thanks
View Kelly's profile
Kelly
2044 posts in 2997 days
#3 posted 04-18-2018 04:35 PM
When I installed a few, I had to insert both, on end, then lift them both to just above the first, lower position, install the support pegs. Then I lifted the second and installed its support pins.
