how to cover up a small knot hole
Forum topic by Pabs posted 04-16-2018 01:14 PM 1718 views 0 times favorited 54 replies Add to Favorites Watch
View Pabs's profile
Pabs
259 posts in 3688 days
04-16-2018 01:14 PM
Hi all
I’ve been searching for a good solution and having a hard time finding the answer. I have a board I’m using on a project that had a knot smack in mid span . Small knot. 1/2” at best.
The board is 4 feet by 5 inches wide and the darn knot is sitting pretty smak in the middle of that board so it’s hard to miss!. I will be leaving this wood natural and covering either wit Tung or poly. It’s cherry wood.
what would be the best way to hide that hole?
thanks
-- Pabs
54 replies so far
View bondogaposis's profile
bondogaposis
5148 posts in 2586 days
#1 posted 04-16-2018 01:16 PM
You can’t hide it. Just fill it with epoxy.
-- Bondo Gaposis
View JayT's profile (online now)
JayT
6003 posts in 2445 days
#2 posted 04-16-2018 01:19 PM
You can t hide it. Just fill it with epoxy.
- bondogaposis
Yep, and don’t try to make the epoxy look like the cherry because it will never match. I like to tint the epoxy black on those occasions. Make it a feature instead of trying to hide it.
View bandit571's profile
bandit571
21970 posts in 2918 days
#3 posted 04-16-2018 01:24 PM
Drill it out enough to install a plug made from the same wood. Plug cutters can cut into the face grain of a piece of scrap that matches the wood. Align the grain as best as you can, and glue the plug in. Plane flush with the surface after the glue dries.
View Pabs's profile
Pabs
#4 posted 04-16-2018 02:13 PM
- bandit571
I had considered this but was wondering how that would look…would the perfect circle cutout really stand out? I’ve done it with end grain and they obviously really stand out (which is a desired effect in that case) . But if I were to make the plug from face grain then the only obvious thing would be the contour I guess.
-- Pabs
View Kazooman's profile
Kazooman
1265 posts in 2187 days
#5 posted 04-16-2018 02:22 PM
Why not just get another board?
View Pabs's profile
Pabs
#6 posted 04-16-2018 02:27 PM
- Kazooman
ha….well, a few reasons. I had done some work to this board before noticing this knot and it’s gonna be something I give away to a friend so rather not waste a full board for something I’m not getting paid for :)
-- Pabs
View AlaskaGuy's profile
AlaskaGuy
4981 posts in 2543 days
#7 posted 04-16-2018 03:10 PM
Trying to hide will most likely make it look worse. Of course it’s hard to tell when all we know its aboard. That’s not a lot of information to go on.
View ChefHDAN's profile
ChefHDAN
1227 posts in 3084 days
#8 posted 04-16-2018 03:30 PM
Had the same problem with this entertainment center , I increased the depth forgetting that my original width was because of some defects and had to make three heart shaped patches (Dutchmen) to cover (see pics in project).
1) I drew some hearts in sketchup, printed them and used them as a pattern to make a template from 1/4” ply with the heart shapes.
2) Used an inlay kit with the templates to cut out the defect areas
3) removed the bushing spacer, and then cut the outlines in a piece of cherry from the same tree to make the patch.
4)Took the board to the bandsaw and then resawed the patches out
No they’re not perfect and indistinguishable, and I did purposely skew the grain alignments to try to feature the fix rather than hide it.
View mel52's profile
mel52
625 posts in 499 days
#9 posted 04-16-2018 03:33 PM
Let my wife talk to it. When she is done, the board will feel so bad it will fix itself. LOL.
-- MEL, Kansas
View CaptainKlutz's profile
CaptainKlutz
687 posts in 1729 days
#10 posted 04-16-2018 03:35 PM
+1 = new board. or
+1 = Either drill out the knot or if only one side is displayed: use a router with inlay template guide and circle template and cut 1/2 thickness deep around knot. Then find another board with same grain pattern, and cut out an inlay patch. With careful selection of plug/patch, knot repair can be invisible to everyone except another wood worker.
- bandit571
View Rich's profile
Rich
3988 posts in 824 days
#11 posted 04-16-2018 03:54 PM
I’d have laid the cuts out to avoid the knot, but if I found myself in a situation like that, I’d use epoxy putty. It comes in various colors that can be mixed, tinted with pigment or dye in order to achieve pretty much any color. I’d fill the knot with it (after testing recipes and allowing them to harden to match the base color of the wood), sand it smooth and then use Prismacolor pencils to match the surrounding wood.
I keep thirty or so pencils in my repair kit in various wood shades and warm greys, etc. They work beautifully on the epoxy and also on Timbermate. You really don’t have to be an artist, the idea is to obscure the edges and give some variation to the overall patch so it doesn’t attract the eye. I use Timbermate to patch worm holes in mesquite and I’ve gotten to where they blend so well, even I can’t find them when I go back and look.
Mohawk Blendal sticks are great too, but since you can go to any art supply store and get pencils for $1.50 apiece, it’s the easier way to go. Take a piece of the wood to the store and pick out three or four colors that will complement the board.
BTW, you don’t just color the patch, you want to go across the edges to obscure them. Use your finger to soften/blend the pencil lines.
View rwe2156's profile
rwe2156
3230 posts in 1715 days
#12 posted 04-16-2018 04:02 PM
Fill with epoxy but best to tint to match color.
I generally use artists acrylic paint.
You’ll probably be surprised ;-)
View Fresch's profile
Fresch
368 posts in 2155 days
#13 posted 04-16-2018 05:06 PM
Go buy a silver coin that fits over the hole, buy the year of birth for who you are making it for.
bandit571
#14 posted 04-16-2018 05:45 PM
Just pine…...
View bonesbr549's profile
bonesbr549
1579 posts in 3301 days
#15 posted 04-16-2018 06:24 PM
if you can’t hide it accentuate it! Make a butterfly inlay or bowtie. Me, I’d just shoot it up with cryocyclolate and make it solid and go on. But an inlay would be cool!
showing 1 through 15 of 54 replies
