Removing wax from a bowl
Forum topic by rizay posted 05-20-2011 12:54 PM 1167 views 0 times favorited 3 replies Add to Favorites Watch
View rizay's profile
rizay
73 posts in 3080 days
05-20-2011 12:54 PM
I need to remove carnuba wax from a bowl. I tried sanding but the sanding disc clog up from the wax. Any ideas on how to get it off?
-- Come visit me at WoodChux and see my work, get free woodworking plans, and find the lowest priced bottle stopper kits around.
3 replies so far
View miles125's profile
miles125
2180 posts in 4000 days
#1 posted 05-20-2011 01:02 PM
Naptha will get it off.
-- "The way to make a small fortune in woodworking- start with a large one"
View Roper's profile
Roper
1389 posts in 3707 days
#2 posted 05-20-2011 03:05 PM
rechuck it and cut of the first layer of wax.
-- Roper - Master of sawdust- www.roperwoodturning.com
View Steven H's profile
Steven H
1117 posts in 3054 days
#3 posted 05-20-2011 04:53 PM
Paint Thinner, Naptha will dissolve it.
However the real trick is getting the wax off once you have it dissolved. If you are just wiping in swirls like the kid at Denny’s wipes your table, you are just smearing the wax around. When the mineral spirits evaporates, you will be left with the wax still on the surface.
The way to go about it is to always keep a fresh face on your wiping rag. Only take one long stroke, then change the face for the next stroke. After you have done the whole surface that way, do it again but wipe across the surface again keeping a fresh face on the rag. Finally, wipe the surface dry with un-embossed paper shop towels again only taking one stroke before changing faces.
