| Forum topic by WhiskeyWhiskey | posted 737 days ago | 1248 views | 0 times favorited | 16 replies | ![]() |
737 days ago |
Hi Guys and Gals – I am looking for a wood lathe “My first one” and JWL-1220VS: 12” X 20” Variable Speed Wood Lathe is what I am looking for. My question is two folds; First: Why do I need a Variable speed Lathe, what can I do with it? -- Whiskey-Whiskey Out.... |
16 replies so far
#1 posted 737 days ago |
To keep it short, big wood must spin slow, small wood must spin fast. Sanding and finishing turn fast. Bottom line, you are constantly changing speeds. Variable speed makes this faster and easier to do. - If you only turn pens; then a 5 speed machine will do fine; and save some money. - If you want to do a wide range of stuff, including bowls, you need a bigger machine, more HP, and VS. -- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason. |
#2 posted 737 days ago |
After much reasearch, I got the Jet JWL-1220vs in 09/09. I started by making a large lamp out of maple. Then 2 bowls to get the feel of the tools. Now I’ve made pens, bottle stoppers, salt & pepper set, etc. The veriable speed ability is a plus. I’ve also found that the 3/4 HP motor is enough for my projects. -- SOLTC |
#3 posted 737 days ago |
Crank49 summed it up well. Think about it… The larger the diameter of the piece you are turning, the greater the velocity of its outer edge. No way can you turn a 12” bowl at the same rpm as you would turn a pen, so changing speeds is an absolute necessity. Non-variable speed lathes usually accomplish this by using stepped pulleys. Every time you want to change speeds you must stop and move the drive belt. A variable speed control allows you to change speeds with a lot less time and effort. -- Charlie M. "Woodworking - patience = firewood" |
#4 posted 736 days ago |
Motor control variable speed or pulleys? -- When the moderator chooses sides, his site sucks. |
#5 posted 736 days ago |
Be aware that ‘variable speed’ can mean electronic control OR a mechanical ‘cone’ system which has a lever that requires some effort to move to change speed. The electronic version is more expensive, but much nicer and convenient to use. I wish I had the electronic version! -- Don, Somerset UK, http://www.donjohnson24.co.uk |
#6 posted 736 days ago |
If you get a VS, you won’t regret it. If you don’t, you’ll always be wondering why you didn’t. Go for the VS if you can possibly afford it, or wait till you can. You won’t regret it. I love mine, and I miss it whenever I use a non VS unit. -- Backer boards, stop blocks, build oversized, and never buy a hand plane-- |
#7 posted 736 days ago |
I’m just east of Dallas and wondered over what kind of lathe to get for a start. After a lot of research and watching reviews here I took a chance on the 33” variable speed from Harbor Freight. Not the one with the tube rails, but a cast bed. I’m not constantly using it all the time due to time constraints. (Always other projects that need to get done.) But it has been excellent for me. For less than $300, it is a great deal. Not as fancy as some of the Big brands but works great. Plus it leaves a little more coin in your pocket for accessories like turning tools and chucks, etc. -- Robert - Haven Wood Crafts |
#8 posted 735 days ago |
Wow – Thanks for all the in site guys. From what I gather, I should ink up on the VS lathe. Anyone have an idea on which one I should go with or is Jet the best. -- Whiskey-Whiskey Out.... |
#9 posted 735 days ago |
Variable speed all the way, but you need to turn the speed down to sand. -- Roper - Master of sawdust-www.coloradocustomworks.com |
#10 posted 735 days ago |
I’ve had the Rikon 70-100 for a few years now. I’m very happy with it. I don’t have any problem at all changing speed with pully’s. Check out the reviews of lathe’s and let those influence your decision. |
#11 posted 735 days ago |
I have a Jet VS and it is a great lathe. -- We must guard our enthusiasm as we would our life - James Krenov |
#12 posted 735 days ago |
My Grizzly VS (sheeves drive) has been a good lathe. All I’ll ever need unless I want to turn HUGE stuff. -- bill@magraphics.us |
#13 posted 735 days ago |
As noted above, there are electronically controlled VS and mechanically controlled VS. The mechanical drives use a Reeves System that increases and decreases the effective diameter of the pulleys. For me, a key issue is slowest speed possible. My mechanical VS will go down to about 500 rpm when the belt is new. As the belt stretches and wears the lowest possible speed goes up. Note that these systems are hard on belts and they wear out quickly. With 500 rpm, I’m comfortable turning a 10” bowl and I have turned a 12” bowl. However, the 12” was really too big and I would never go any bigger than that despite having clearance over the bed for up to 16”. Electronically controlled VS can go as slow as you want. Someday I will replace my mechanical VS with an electronic one. -- Rich, Cedar Rapids, IA - I'm a woodworker. I don't create beauty, I reveal it. |
#14 posted 735 days ago |
I would also check out the Delta VS Model 46-460. $50 cheaper and more swing and slower speed. Bed is 3 1/2 inches shorter though. It is the one I’ve been looking at. HF tools are a crap shoot . I ‘ve had very good luck with their drill press and some of their other tools. I’ll have to take a look at their VS midi type lathe. |
#15 posted 735 days ago |
Electronic Variable Speed -- Only the Shadow knows.................... |
| Forum | Topics |
Woodworking Skill Share
8799 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1538 |
3556 |
15818 |
Hand Tools
2040 |
Jigs & Fixtures
496 |
Wood & Lumber
2847 |
810 |
Focus on the Workspace
904 |
766 |
Woodworking Trade & Swap
2742 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6167 |
