| Forum topic by Ben | posted 736 days ago | 948 views | 1 time favorited | 11 replies | ![]() |
736 days ago |
I am working on a couple of cutting boards to be sold for charity. Its my first time making boards and I have run into a problem. I have the strips glued up and was running them through the planer to level them off a bit and I noticed a weird looking spot on one of the strips of maple. It looks like pitting or something like that. I kept running it through the planer hoping it would eventually clean up, but i dont think its going to. The board is still over 1 inch thick, so I could keep going in the planer if it will clean up. I tried hitting it with some sand paper and it just fills the pits with dust. Well I am sure this is not the type of thing you would desire on the top of your cutting board. I would flip it and use the other side as the top, but of course there is a spot on a separate strip on that side. It is on the outermost strip so I guess i could cut the whole strip off and narrow the board up. Has anyone seen similar issues… any suggestions?
-- Ben in Houston |
