Full extension wooden dovetailed slide make out of IPE for drawer side
Forum topic by v8extra posted 05-19-2011 01:32 AM 3805 views 0 times favorited 0 replies Add to Favorites Watch
View v8extra's profile
v8extra
18 posts in 2752 days
05-19-2011 01:32 AM
Hello to all,
Here is my project, I am planning to build a coffee table. That table is low 15,5 ” inch high.
Under this table I which to install a drawer that will be supported only by its side.
It will be a small 3 1/4” high (drawer front).
The square table is 40,5” wide with square legs also 3 1/4” inch wide.
My question is the following,
1- In order to save some leg space (playing cards sitting on the floor), I intend not to put a bottom to the table.
As a consequence the drawer can only be supported by the inner side of the legs and an internal plank that flush with the internal part of the leg.
2- For example would such a concept be worth trying http://lumberjocks.com/gfixler/blog/13478, for side mounting.
3- In any case I wish to receive suggestions and ideas regarding full extension wooden slides I should use to hold two drawers that will be place in the table.
4- Best would be to also consider the fact that I wish to have a system that will also well behave in terms of wood movement throughout the season.
Thanks!
Thanks a lot for all your comments.
Sebastien
I will soon be adding an updated table model here…
0 replies so far
